Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: rear split on 8n
[Return to Forum]
jeff tompkins
08-30-2012 06:27:29
24.176.56.171
How big a job is it to do a rear split on a 50' 8n? one person do it ok? any helpful tips!! THX, Jeff
[Reply]   [No Email]
Hobo,NC
08-30-2012 18:15:33
75.117.64.93
 Re: rear split on 8n in reply to cmcgalla, 08-30-2012 06:27:29
[quote="JMOR"](quoted from post at 22:59:33 08/30/12) Quoting Removed, click Modern View to see
Yep that would keep me busy for awhile,,, on the first pix I would atemp a file job... TOH the customer wanted to use the old shaft that's what he got his call... The shift coupler had a twist also it got a file job also...
[Reply]  [No Email]
TheOldHokie
08-30-2012 13:15:10
108.8.13.83
 Re: rear split on 8n in reply to JMOR, 08-30-2012 06:27:29
[quote="JMOR"](quoted from post at 14:59:33 08/30/12) Quoting Removed, click Modern View to see
Anytime you file you compromise a rather tightly controlled fit. The maximum allowable side clearance on an 1-1/8 SAE 6B (sliding) spline fit is .002" with no more tha .006" out of parallel per foot. That's darn little filing.
TOH
[Reply]  [No Email]
soundguy
08-30-2012 16:37:12
107.41.3.146
 Re: rear split on 8n in reply to TheOldHokie, 08-30-2012 13:15:10
guess you could file it to get it out, to save cutting.. but if it's bad.. I'd think I'd want a new shaft anyway.. once twisted.. who knows when it may twist more or fracture...
[Reply]  [No Email]
JMOR
08-30-2012 11:59:33
72.181.173.171
 Re: rear split on 8n in reply to badger bob, 08-30-2012 06:27:29
[quote="Hobo,NC"](quoted from post at 14:40:06 08/30/12) Quoting Removed, click Modern View to seeGuess it depends on how bad twisted. File this one straight.
:wink:
[Reply]  [No Email]
Hobo,NC
08-30-2012 11:40:06
75.117.64.93
 Re: rear split on 8n in reply to Douglas Lloyd, 08-30-2012 06:27:29
[quote="JMOR"](quoted from post at 19:31:15 08/30/12) Quoting Removed, click Modern View to seeyes
I have had to do a split one time for a shaft that would not come out,,, I filed the splines straight and the shaft came out,,, I even reused the shaft :shock:
All you need is a file that fits the spline perfect,,, a good one will do the job rather quick...
[Reply]  [No Email]
JMOR
08-30-2012 10:29:22
72.181.173.171
 Re: rear split on 8n in reply to Elvin Frank, 08-30-2012 06:27:29
Quoting Removed, click Modern View to seeRight above the picture, do you see a word? A 3 letter word, starting with "y"?
[Reply]  [No Email]
JMOR
08-30-2012 08:31:15
72.181.173.171
 Re: rear split on 8n in reply to Ken(Ark), 08-30-2012 06:27:29
[Reply]  [No Email]
soundguy
08-30-2012 11:01:15
107.31.32.83
 Re: rear split on 8n in reply to JMOR, 08-30-2012 08:31:15
i love that pic!
so simple looking.. yet you just know it's a bit of a PITA :)
[Reply]  [No Email]
jeff tompkins
08-30-2012 10:03:00
24.176.56.171
I have viewed that pic, my question is, if I do a rear split does
that get the big drive shaft out of the way, like in the pic???
THX, Jeff
[Reply]  [No Email]
JMOR
08-30-2012 08:14:53
72.181.173.171
 Re: rear split on 8n in reply to ericlb, 08-30-2012 06:27:29
Wedges at front axle to prevent tipping is a good plan too.
[Reply]  [No Email]
TheOldHokie
08-30-2012 07:59:05
108.8.13.83
Pretty darn easy. Drain the oil, disconnect brake linkages, muffler mount, PTO shifter, and any rear wiring, unbolt the center section, and roll the two halves apart. One man can do it with no problems using a jack stand and floor jack. I suggest finding a nice smooth and level concrete surface for the job :idea:
Probably 1-2 hours to split and another 1-2 to reconnect everything if there are no stubborn fasteners.....
TOH
[Reply]  [No Email]
jeff tompkins
08-30-2012 08:24:55
24.176.56.171
 Re: rear split on 8n in reply to TheOldHokie, 08-30-2012 07:59:05
when I do the rear split, does that get the drive shaft out of
the way above the hyd pump so I can cut my pto shaft?
[Reply]  [No Email]
Jim.UT
08-30-2012 11:55:53
70.89.244.178
 Re: rear split on 8n in reply to jeff tompkins, 08-30-2012 08:24:55
Yes, on a rear split, the drive sleeve just slides off after you pull the tractor apart. Don't forget to put it back in before you bolt it all back together!
[Reply]  [No Email]
Ultradog MN
08-30-2012 07:52:51
70.56.166.171
 Re: rear split on 8n in reply to jeff tompkins, 08-30-2012 06:27:29
Jeff,
Rear split is actually easier than a front split.
No tin, wires, gas lines, radius rods or tie rods to deal with.
I block the front half up under the tranny then use a floor jack to roll the rear half back.
I Always use wooden cribbing to block up a tractor as I just do not trust steel on steel (or cast iron) jackstands.
What is wrong that you have to split it?
Photo is not of a rear split or even of an N but does show proper cribbing with wood blocking.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
