| Ford 9N, 2N & 8N Discussion Forum |
Topic: Tire chain length for 12.4-28 tire
[Return to Forum]
| Author |
[Modern View]
| TB in MN
08-29-2012 17:19:55
71.51.150.138
What is the best way to know if used tire chains will work with a 12.4-28 ag bar type tire? I currently have ladder style chains that are 10" long and 20" wide which I struggle to be long enough even though many of the ladder rungs have settled between the lugs. I see an add for 12'8" long 24" wide used duo grip type chains which will have the benefit of staying on top of the lugs but an extra 2'8" of tire chains seems to long. Add says they will fit tires up to 4"5" diameter but my tires measure 4" diameter. Can someone confirm if they will fit on my tires?Thanks, TB |
[Reply] [No Email] | |
| Charles Krammin
08-30-2012 06:18:18
69.174.184.231
Re: Tire chain length for 12.4-28 tire in reply to TB in MN, 08-29-2012 17:19:55
| | My road chains for my 12.4 X 28 measure 100" long. The cross links are 23" Charles Krammin SW MI |
| howdy1960
08-29-2012 21:09:04
173.191.206.106
| glad my biggest math problem right now is how much power to run and how long to run the power to cad plate my wheels. anyone how what thickness the plating was? |
| Royse
08-29-2012 19:22:29
69.36.49.151
Re: Tire chain length for 12.4-28 tire in reply to Del Huebner, 08-29-2012 17:19:55
| That's because you're measuring the length of the outside chain, and that outside
chain fits down over the edge of your tire closer to the rim, not around the center of the tire.
I don't have the measurement off the top of my head, but if someone else doesn't
have it handy I'll measure my chains for you tomorrow.
Too long is better than too short. They can be cut down to fit. |
| TheOldHokie
08-29-2012 19:19:28
108.8.13.83
Re: Tire chain length for 12.4-28 tire in reply to James Jr., 08-29-2012 17:19:55
| Quoting Removed, click Modern View to see
Your math is fine but your statement of the problem is incorrect. The diameter in question is not the outside diameter of the tire. It is the circle the side chains make whiich is a function of the width of the cross chains when laid over the tire and generally closer to the diameter of the wheel/rim. So overall length = 3.14 x 28 = 88 inches for cross chains that go from bead to bead. Longer if the cross chains are shorter. Shorter if the cross chains are longer.
TOH |
| TB in MN
08-29-2012 20:11:07
71.51.150.138
Re: Tire chain length for 12.4-28 tire in reply to TheOldHokie, 08-29-2012 19:19:28
| | Understood and very well stated. Obviously, there are many combinations of chain length and width that will work which would cause the chain to be nearer and further fom the rim diameter. 24" wide chains on a 12" wide tire would wrap around the sides of the tire by 6" on each side. On a 48" tire the side chains would then be on a 36" diameter (~9'5" circumference). Based on that, 12'8" chains would have to be cut much shorter to work on a 12.4-28 tire. Always helps to talk through a problem. The answer is what I suspected although I hoped someone would say they somehow made it work on their tractor which is why I asked. Of course one could if they cut the chains shorter or used chain tensioners. Thank you, TB |
| Bob Harvey
08-29-2012 18:01:07
209.91.107.195
| I know I'm gonna sound like an axxWhole. Didja go to beyond the 5th grade? Pretty simple math to find out what you need to know. Yep the info is here, and some smarter folk will show up. H.P.H. |
| TB in MN
08-29-2012 19:09:41
71.51.150.138
Re: Tire chain length for 12.4-28 tire in reply to Bob Harvey, 08-29-2012 18:01:07
| | 48" tire diameter x 3.1459 = 12'6" circumference. Sounds great but... My 10' chains would theoritically fit a circumference of 38" (120/3.1459) but actually fit on a 48" tire. This leads me to believe 12'6" chains may be too long. I was hoping someone would know by actual experience. TB |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
