| Ford 9N, 2N & 8N Discussion Forum |
Topic: hydro filler opening?
[Return to Forum]
| Author |
[Modern View]
| modyinnh
08-29-2012 10:40:01
130.189.10.63
Hey, Still pretty new to my '48 8N. I checked my hydraulic fluid at the dipstick.. It was low (actually it didn't register). Where, O where do I add the fluid? Checked both owners and shop manual. No mention that I could find. Right next to the Position Control lever is a slotted screw/bolt. Is that the filler opening? 3Pt seems to only lift my ground driven hayrake when it feels like it so I thought adding fluid would be a place to start.Paul |
| CharnerL
08-29-2012 14:46:01
66.175.149.166
Re: hydro filler opening? in reply to modyinnh, 08-29-2012 10:40:01
| Make sure you don't overfill with oil. It has a tendency to get into the rear wheels via the rear axle housing. I use the lower bolt on the inspection plate, right side, to gauge the level. When it starts coming out, let it run 'til it doesn't come out anymore. Bolt back in. Sometimes the dip stick registers full and then the oil still settles down and its actually over full. |
| Billie R. Smith
08-29-2012 10:43:45
69.245.108.151
| Big square hex filler plug next to the shifter lever. Tran,pump hsg,and rear end use a common sump. |
| modyinnh
08-29-2012 11:19:10
130.189.10.63
Re: hydro filler opening? in reply to Billie R. Smith, 08-29-2012 10:43:45
| Ah yes. Was wondering what that was. Thanks! |
| soundguy
08-29-2012 11:36:56
173.107.43.79
Re: hydro filler opening? in reply to modyinnh, 08-29-2012 11:19:10
| | sup holds about 5g oil. oem was similar to a 90wt gl1 / gl3 oil.. napa 65-205 is that oil in a 90wt mineral gl1.. tsc sells a ?gl3 oil that's probably similar. you could also use a 80w90 gl4/5 oil that carries a MT1 rating that is labeled as yellow metal safe.. ( many people use an 80w90 that is not yellow metal safe.. I personally would not reccomend it ias it can start causing minor , slow, long term corrosion on the yellow metal in your N hyd pump.. though it certaintly won't cause somethng to fail anytime soon ). you can also fill with a UTF oil meeting a ford/nh M2C134spec ( you will find specs A thru D.. any will work.. A is older.. D is the latest.. your N was made before that spec.. so any is fine.. :) ) |
| modyinnh
08-29-2012 11:53:50
130.189.10.63
Re: hydro filler opening? in reply to soundguy, 08-29-2012 11:36:56
| I got some from my local NH dealer. I'm at work so I cant check the spec. He assured me it was the right stuff. |
| soundguy
08-29-2012 12:17:27
173.107.43.79
Re: hydro filler opening? in reply to modyinnh, 08-29-2012 11:53:50
| | probably ambraG, spendy oil. for an N.. just about ANY utf oil would work. nowthen. if the machine has gear oil in it.. you are topping off with utf. I wouldn't purposefully mix them.. but I'd not run it without oil either... that would be the worse of the 2 evils.. :) one day you really should do a sump change and cleaning and go in with a specific oil type vs a possible mix. |
| modyinnh
08-29-2012 12:21:10
130.189.10.63
Re: hydro filler opening? in reply to soundguy, 08-29-2012 12:17:27
| Good idea. I've got a list of things to do on her after hay season is over. I'll add that. |
| soundguy
08-29-2012 12:33:08
173.107.43.79
Re: hydro filler opening? in reply to modyinnh, 08-29-2012 12:21:10
| good deal. even if it's utf and gear oil mixed, for now you should be ok.. some type of oil is better than no oil... |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
