Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: PTO Shaaft Replacement
[Return to Forum]
Justin D
08-27-2012 06:43:52
24.144.199.186
I replaced the PTO shaft on my '46 2N last night. When the 4 bolts that hold it in-place are slightly loose the shaft turns fairly easily by hand. When I tighten the bolts as little as finger tight, the shaft will not turn. Is this normal? I am assuming that it is from the bearings being slightly compressed as I tighten the bolts but before I put the fluid back in the tractor I figured that it would be a good idea to make sure that I am not doing something wrong or that something is not lining up quite right.
[Reply]   [No Email]
R Geiger
08-27-2012 15:30:59
50.39.138.117
 Re: PTO Shaaft Replacement in reply to Bruce (VA), 08-27-2012 06:43:52
Might loosen the bolts on the pump and then turn the shaft. let everything find a new center, then tighten bolts.
[Reply]  [No Email]
CharnerL
08-27-2012 15:01:47
66.175.158.120
 Re: PTO Shaaft Replacement in reply to Justin D, 08-27-2012 06:43:52
Check the length of the new one against the old one. If new one is longer, grind the end down.
[Reply]  [No Email]
Justin D
08-27-2012 06:55:48
24.144.199.186
Yes, I have a gasket on it. It is a brand new shaft as I decided to upgrade to a 1-3/8 shaft.
[Reply]  [No Email]
soundguy
08-27-2012 07:38:22
173.107.39.118
 Re: PTO Shaaft Replacement in reply to Justin D, 08-27-2012 06:55:48
put a blob of grease on the end o fthe shaft.. stab it in pull it out.. grease smashed flat? / gone from lack of clearance?
if so.. :) I might grind 1/16" of fthe nd fo the shaft.
sounds like a chinese clearance problem to me.. :)
another test..
cut a gasket using yours as a template. cut it out of some thick gasket paper.. exhaust gasket paperboard.. put that on. if it turns fine.. um.. I'd bolt it in tight... :)
[Reply]  [No Email]
Justin D
08-28-2012 05:02:32
24.144.199.186
 Re: PTO Shaaft Replacement in reply to soundguy, 08-27-2012 07:38:22
I put the new shaft beside the old shaft and the difference in length, if any, could not be seen by just looking at them. However, I took some 1/32 gasket paper and cut out a gasket using the standard gasket as a template as you suggested. I installed the fabricated gasket along with the gasket that came with the new shaft and still had the same problem. I then cut out a second gasket and installed it again with all three gaskets and it worked. The additional 1/16" in gasket material was what it required. Thank you for you suggestions!
[Reply]  [No Email]
soundguy
08-28-2012 09:12:14
184.233.253.202
 Re: PTO Shaaft Replacement in reply to Justin D, 08-28-2012 05:02:32
soulds like the sahft is a hair too long.. or it loacates in the bearing carreir slightly wrong.
the gasket fix is not perfect.. but works..
[Reply]  [No Email]
soundguy
08-27-2012 06:46:25
173.107.39.118
got a gasket on it?
bearings goot in the shaft?
spline end that goes into pump damaged or mushroomed?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
