Topic: points
[Return to Forum]
| Author |
[Modern View]
| nolan in texas
08-21-2012 22:00:33
67.142.165.23
any one know were i can buy bluestreak points for a 54 ford naa tractor, if so what is the part #. nolan |
| BIG_EASY
08-22-2012 11:07:39
108.91.4.33
Re: points in reply to nolan in texas, 08-21-2012 22:00:33
| Your list says that a 12 volt coil does not need a resistor - it that correct? I thought that a resistor was necessary. |
| Bruce (VA)
08-22-2012 12:55:33
24.125.80.178
Re: points in reply to BIG_EASY, 08-22-2012 11:07:39
| " it that correct? "Soundguy just tosses bogus stuff out like that to see if we're paying attention..........messing w/ the newbies. :) Yes, it's correct. The question concerned a round coil on an NAA. A 12v round coil on an N or an NAA does not need a resistor. Unless it is clearly marked that it needs one......in which case, buy another coil like the IC14SB Soundguy listed. A square front coil on an N always needs the OEM ballast resistor. Doesn't matter if it's 6v or even if it's a 12v coil. |
| nolan in texas
08-23-2012 20:06:04
67.142.165.21
Re: points in reply to Bruce (VA), 08-22-2012 12:55:33
| thanks guys for the info, nolan |
| soundguy
08-22-2012 11:23:33
107.41.212.71
| | did i stutter? a napa ic14sb is a 12v native coil.. primary resistance is fine for 12v.
a '12v' coil that needs a resistor is a 6v coil. a 6v coil plus the appropriate resistor can be run on 12v. it's printed that way for a reason.... |
| old
08-22-2012 09:31:03
209.86.226.34
| O'Reilly's carries B%W points which are also one of the top of the line parts companies and I know there has to be a O'Reilly's not to far from you |
| soundguy
08-22-2012 05:20:14
184.245.35.34
| | points,cap,rotor, etc.. are the same on side mount 8n, naa, 00/01 and up thru 64 4 cyl models. ANY of the premium points listed below are fine .. even the basic echlin / napa. BW are fine too.. just about anything other than tisco.. :) Side-Mount Distributor: Points: NAPA #CS749 NAPA HEAVY DUTY PIERCED (ventilated) #CS753 Standard Ignition #FD-8081 Standard Ignition Blue Streak #FD-8081X (Premium) Condensor: NAPA #FA66 Standard Ignition #FD-75 Standard Ignition Blue Streak #FD75X (Premium) Rotor: NAPA #FA67 Standard Ignition #FD-108 Distributor Cap: NAPA #FA352 Standard Ignition #FD-128 6 volt coil IC7 ($48) 6 volt voltage regulator VR950 6 volt coil IC7SB ($23) 12 volt coil, no resistor needed: IC14SB |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
