| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8N oil pressure
[Return to Forum]
| Author |
[Modern View]
| basil greenleaf
08-21-2012 14:04:28
64.112.199.98
Help, I am going crazy. I can not get engine oil pressure on my 1948 8N. I have blowen out every line. When I apply air pressure to the outlet T air comes out the pump inlet hole. I have completely rebuilt the pump. New small gears, new large drive gear, and had the bushing reamed to fit the gear shaft. Have checked the pump pickup tube and canister for leaks. Have primed the pump several times and started the engine after priming. Have removed the spring and plunger completely and tried it and have installed washers to increase the oil pressure. Nothing helps. I stil canot get oil to come out the outlet T at the back of the engine. The pump gears are turning when the engine turns over. One other thing, I tried turning it by hand with the pickup tube in oil and it pumps. Help, help. Thanks, basil |
| JMOR
08-23-2012 18:56:32
72.181.173.171
Re: 8N oil pressure in reply to Ron-MO, 08-21-2012 14:04:28
| Quoting Removed, click Modern View to seeWell, I don't know what the "top half" is on a flat head, but I guess tat isn't important. On some motorcycles where I can change out the cylinders & pistons & leave the crank assy un-touched, it makes sense. Anyway, back to the subject at hand. Yes, if it is pumping, there should be oil coming out at all the bearings, etc. See the attached oil circuits.
| JMOR
08-23-2012 18:10:19
72.181.173.171
Re: 8N oil pressure in reply to terry/mich, 08-21-2012 14:04:28
| Quoting Removed, click Modern View to seeWhat is different that you are doing now, than what you were doing here: "One other thing, I tried turning it by hand with the pickup tube in oil and it pumps."? |
| basil greenleaf
08-23-2012 18:17:59
64.112.198.190
Re: 8N oil pressure in reply to JMOR, 08-23-2012 18:10:19
| Yes, I turned the pump with the drive gear as fast as I could with the pick up tube in oil and it pumped oil out the small oval shaped hole in the casting. I did primp it prior to turning it over. I also primed it many times with it installed down through the plunger hole, but it did not do the job. Basil |
| lha
08-22-2012 19:22:49
24.176.101.87
Re: 8N oil pressure in reply to basil greenleaf, 08-21-2012 14:04:28
| Like someone said,You should check the pressure against a known good gauge. You could get a cheapie gauge at an auto parts store,hook it up and see what happens.You could also disconnect the line at the oil filter,sit a pan under it,and crank it and see if oil comes out. A heater hose attached to the line going into the governor will work to determine flow. lha |
| Greg 2N (TX)
08-22-2012 10:40:39
129.162.1.41
| | Sounds like a missing galley plug since you said you can't get oil out of the T at the back of the engine. Hope it isn't your pump gears having too much end-play. Someone else will jump in and help. Best wishes, Greg |
| curtsat15
08-22-2012 05:56:23
206.45.224.21
| Check your oil pressure gauge, it may be faulty. |
| CharnerL
08-21-2012 20:20:12
66.175.155.211
| You know there is an oil drian hole just in front of the plunger. Could it be that the plunger may not be seating and allowing the oil to return to the pan. Try to apply air pressure to the oil filler tube so pressure will build up in the pan and force the oil up the pick up tube while you are cranking. It helps to remove the plugs while you are trying this. |
| basil greenleaf
08-23-2012 18:06:22
64.112.198.190
Re: 8N oil pressure in reply to CharnerL, 08-21-2012 20:20:12
| I have the oil pan off. I am feeding the pick up tube with from a bucket of oil. Pick up tube canister is fully emerged in oil. What I am saying is that the rebuilt pump is not picking up the oil. Oil should be spraying everywhere with the egine running, but there is zip. (no oil) |
| HCooke
08-21-2012 15:31:05
70.195.66.248
| Was your engine recently overhauled? Did you or the rebuilder perhaps leave out the galley plugs? Its happened before. |
| basil greenleaf
08-23-2012 18:21:47
64.112.198.190
Re: 8N oil pressure in reply to HCooke, 08-21-2012 15:31:05
| Should there be oil dripping everywhere if the pump is working and the gally plugs were left out. The engine has been rebuilt but the top half only. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
