| Ford 9N, 2N & 8N Discussion Forum |
Topic: Oil pressure
[Return to Forum]
| Author |
[Modern View]
| Dave/MO
08-19-2012 08:47:34
173.186.176.151
What is an exceptable oil pressure? just changed oil and gauage is reading 20psi at idle and gos to about 25psi at high rpm with no load. Will the pressure change with a load? Just curious. |
| ASEguy
08-19-2012 16:29:06
68.186.162.134
Re: Oil pressure in reply to Dave/MO, 08-19-2012 08:47:34
| Pressure changes, at a given viscosity, with engine speed and temperature. Operating temperature and idleing are usually when readings are interpreted. 20 psi idleing at operating temperature is good. |
| Colin King
08-19-2012 12:03:45
67.233.229.23
| | I think your numbers are great. As John points out, there is a lot of range on these engines, which depends on their history. You'll probably see somewhat lower readings after the engine has worked hard for a few hours. Colin, MN |
| NOXJohn
08-19-2012 10:21:21
184.5.164.213
| That is pretty good oil pressure. The real test of how tight the engine is would be to work the tractor hard for a couple of hours in the hot summer and then check the running and idle oil temperature. For a tractor in decent shape I would expect 20+ running and 15+ at idle after running hard for several hours. That is with 15w-40 motor oil. Lower oil pressure does not mean it is time to rebuild the engine. I ran a 1949 8N hard with 10 pounds of running pressure and 5 pounds of idle pressure for 20 years. I did not find any damage when I finally tore it down to rebuild. |
| old
08-19-2012 09:51:08
209.86.226.19
| While that set of numbers are not super good they are not all that bad either., These old tractor run just fine with as low as 5PSI. Also depends on what oil you use. A straight weight tends to hold better pressure then a muti weight oil does |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
