| Ford 9N, 2N & 8N Discussion Forum |
Topic: PTO Shaft Leak
[Return to Forum]
| Author |
[Modern View]
| John Leonard
08-17-2012 03:14:51
67.162.28.147
Hi, the 1951 8N that my grandfather bought new was restored by me and was given back to my sister in May. Nobody wanted to pay the big $ I thought it was worth, so I just decided to keep it in the family.It has had a slight problem that I need to work on now. There is a small leak of hydraulic fluid from the PTO shaft. I guess it"s coming from a bad seal around the shaft"s output, so my sister"s ordering a new seal and gasket. Before I tear into it, does anybody have any advice? Is it going to be an easy fix (I hope, I hope)? Thanks. John Leonard DeKalb, IL 1951 Ford 8N SN 344016 |
| John Leonard
08-19-2012 14:26:52
67.162.28.147
Re: PTO Shaft Leak in reply to John Leonard, 08-17-2012 03:14:51
| | Just to give an update: we"re gonna do the conversion. I checked prices; they went from a high of $158.30 to a low (on Ebay auction) of $80.00, which is what I got. Shipping added another $10 to $19.25. I guess it pays to shop around. I wish I had known that when I first started the restoration. Thanks again for you help. jbl dekalb, il |
| soundguy
08-18-2012 10:23:49
173.103.166.76
| it's probably one of the easiest repairs you can do on an N.. just above changing the oil. |
| oldtanker
08-18-2012 07:03:41
66.228.255.239
| When I did mine I was lucky enough to have a steep enough embankment that I lost no oil. AS a first timer it too all of 20 min. Just follw the advice posted......and watch out fer yer toes!
Rick |
| Jimps
08-18-2012 06:31:08
99.194.102.58
Re: PTO Shaft Leak in reply to SERVICE CALL..John,PA, 08-17-2012 03:14:51
| Quoting Removed, click Modern View to see
John,
Yes it is. I changed both of my 8N's with a new shaft like you are suggesting. Standard connector at that point.
The task only takes a few minutes. The first one I did while I was working on the hydraulic pump. Took me longer to get that one out since I was a newbie. 2nd one was a snap, took about 10-15 minutes total (nose-down in a ditch). A little oil will come out with the old shaft, not enough to worry about. The shaft is only held in place by the 4 bolts, and the old gasket. Mine were stubborn, but that was mainly the old gasket. New one should slide right on in! The whole thing is one unit, just pull out the old one and shove in the new one.
You will need a new PTO gasket when you install the new one. Part # C5NN747A from this site. Be sure to completely clean/scrape off the old one.
If you plan to use a mower, do yourself a favor and get an OTC (Over Running Clutch).
Hope this helps.
Jimps in GA. |
| John Leonard
08-18-2012 04:50:42
67.162.28.147
| | Thanks for the suggestions! How's this for a plan? Tell my sis to forget about the oil seal and get a 1 1/8"-to-1 3/8" Conversion Kit. (9N-700-38). When it gets here, park the tractor nose-low. Remove the 4 PTO bolts. Pull out the old shaft, oil seal and bearing. Install the new assembly. Tighten the 4 bolts. Is it really that simple? Thanks. jbl DeKalb, IL |
| JoePilot
08-17-2012 09:09:22
205.175.225.12
| | If you don"t have a seal driver set, buy one. They"re only about $30 and well worth it. Also, have your sister buy 3 seals. They"re only $5 each and that"s how many it took me to get it right. Or maybe that"s just me...:-) Joe |
| Dell (WA)
08-17-2012 09:00:14
97.113.108.50
| John........ittza 4-bolt 1-hr job to replace yer PTO seal ...iff'n... you park yer tractor NOSE DOWN innna ditch so you don't haffta drain 5-gals of hydro-tranny oil. Otherwize, guess what??? Me? be prepaired to replace yer PTO shaft with NEW 1-3/8 standard shaft 'stedda' the old 1-1/8 6-spline. .......Dell |
| TOM N MS
08-17-2012 03:48:24
98.95.42.205
| Here is what Bruce says--------------------------PTO SEAL REPLACEMENT --- While you have the PTO shaft out, it would be a good time to replace the seal on it. It"s got two spring clamps around it. Take your needle nose pliers & remove the one in the front. Then, hang the shaft & bearing housing in your vice & tap the butt end of the shaft; the bearing cap will come off (and the shaft will land on your foot). Then, remove the other spring clip from the other side of the seal. At this point, remember that you never bought a seal driver & go get a B socket & drive the seal out. If you have the new style seal, the white side goes out. Put some grease on it..Bruce. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
