| Ford 9N, 2N & 8N Discussion Forum |
Topic: Trying to identify ports
[Return to Forum]
| Author |
[Modern View]
| Jeaux Bleaux
08-13-2012 21:40:50
12.26.249.205
Hi! I'm trying to repair a '51 8N and removed the head to replace the head gasket. I was probing the water jackets on top of the block and found two holes between cylinders 2 & 3 that are much larger than any of the other ports on top of the block. I stuck a wooden dowel about 7" down into this port and came out with about 4" of black oil and sludge on the end of the dowel. No sign of water in there (but I had already drained the radiator). So, is this supposed to be a water jacket area or is part of the crankcase cavity? I drained the oil as well and I can't imagine why there is still oil (4" deep) in this chamber area.All help much appreciated. Thanks! |
| Jeaux Bleaux
08-15-2012 08:43:00
12.26.249.205
Re: Trying to identify ports in reply to Jeaux Bleaux, 08-13-2012 21:40:50
| | Thanks, Ken and John. I appreciate and value your advice. Ken, if I had any money, I'd just send the block to you for rebuilding... :) |
| Ken(Ark)
08-14-2012 15:54:58
71.30.140.79
| Quoting Removed, click Modern View to see
If you just have extra money let me know and I'll send you my paypal number .
If the oil pressure was Ok , I would clean most of the easy stuff and stick the head back on , then use it another 10 years . |
| Jeaux Bleaux
08-14-2012 14:08:50
12.26.249.205
| Thanks for the clarification, guys. Wow! 4" of standing oil/sludge in the bottom of that chamber. Guess I'll tear the entire engine down and clean it thoroughly. |
| NOXJohn
08-14-2012 07:16:45
184.5.164.213
| It is part of the water jacket. What you have found is 50-60 years of accumulated gunk. Clean out as best you can. Since you have the head off you may want to take it to a machine shop and have it cooked or boiled out. It most likely has a lot of gunk in it as well. They can also check to see if it is flat or shave it if necessary. |
| Ken(Ark)
08-14-2012 06:05:50
71.30.140.79
| The water pump is high on the front of the system and the outlet in the head is just above the pump which makes a short route for the water to circulate . The water jackets are very deep too.
The N blocks collect debris and gunk very easily and are hard to flush out . It is very common for N's to get oil into the cooling system .
I would make sure you have a thermostat in the system . Old school philosophy was take out the T Stat and run 40+ weight oil .
A 180 degree NAA Thermostat is debatably better than the stock 160 degree unit . Running the motor in the optimal heat range will help disperse the oily gunk that is settling in the block .
P.S. yes that is a water jacket . The N block does not have holes that go into the crankcase ( except the ones that are used by the valves and guides )
With just the head off all of the open holes go into the water jacket . All of the head bolts / studs go into the water jacket but some may be blocked by years of rust and corrosion . Best to let sleeping dogs lye , the blocked hole will not hurt anything but you might hydraulically break something if you goop up the bolt threads too much , that is if you have bolts .
This post was edited by Ken(Ark) at 06:15:14 08/14/12. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
