Next question on the 8N --side mount
After working on the carb and draining the battery when I went to hook up the charger the positive post was hooked up to the ground to frame strap.
All of the wiring is inside a loom and long term would be to start over with a new harness. However, for the short term do I need to turn the battery around and hook the negative to the ground strap?
I've ran the tractor for about 15 hours set up like this and have no idea how long the PO had it this way.
