Missouri Farmer
New User
My 1950 8N was causing the gas tank to boil so I checked and found that there was no thermostat. I installed the 180 degree thermostat pictured. I put it in the upper radiator hose close to the radiator. The side facing up in the picture faces the radiator.
I started the tractor and the radiator boiled over after a few minuets. What went wrong? I recently read that I should fill the radiator so it just covers the core. I had filled it so it almost covered the round pipe looking object but still had some good air space. Did I install the thermostat correctly?
