Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Rope Seals, Again...
[Return to Forum]
TSWolf
08-05-2012 18:26:44
71.176.139.233
I got the front seals on the 9N replaced, but the upper rear seal is a problem. Part of the old seal is stuck on top of the crank, and the ends have already pulled out. Does anyone have any ideas for removing what is left of the seal without dropping the crankshaft?
[Reply]   [No Email]
36 coupe
08-14-2012 04:59:49
66.186.169.176
 Re: Rope Seals, Again... in reply to TSWolf, 08-05-2012 18:26:44
Take the timing gear cover off.Rope seals should be soaked in oil before using.
[Reply]  [No Email]
Dave Wave
08-14-2012 09:37:25
67.165.128.33
 Re: Rope Seals, Again... in reply to 36 coupe, 08-14-2012 04:59:49
Try a piece of SS stock from a set of old windshield wiper blades. Just perfect to dislodge the seal. You can find a post I wrote about it in the archives. Remember to drop the crank just a bit to give the seal to move, but not so much as to damage the front seal.
-Dave
[Reply]  [No Email]
ZANE
08-06-2012 12:56:59
98.83.97.129
I have never done this on the N engine or the front seal but have done it on the TO Ferguson engines many times.
You can take the timing cover off and replace it easy since the pan is off anyway.
Unless you want to remove the crankshaft don’t even think about trying to remove the upper main bearing seal on the N engine.
There is a better way to fix it if it really needs fixing. First the rear main bearing itself must be in good condition or trying to fix the rear seal is just a practice in futility.
If the rear main bearing is OK you should first remove the hood tank and the front axle and radiator etc. This will give you ample room to drop the pan. This will save much wailing and knashing of teeth!
Obtain an original rear main bearing seal kit for the Ferguson TO 20 engine. This consists of a bottom seal similar to the one used on the N engine and a big ball of cotton roping. Cotton Roping is what a big cotton thread looks like before it is twisted in the cotton mill.
Using a soft welding rod of about 5/32” start packing the cotton roping into the upper seal. Don’t try to remove any of the original upper seal but pack all of the roping you can get into the upper seal slot. The old seal will be compacted and fill any void that is in the upper seal.
Replace the lower half of the seal with an original N seal. Don’t worry about the different colors on the ends of the seal if it matters I haven’t been able to find out what it is in the last 40 years.
I have done this repair many times in the past and never had a leak. The cotton roping is all that the new TO Ferguson tractors ever had from the factory. The engine in them is a Contenintal engine.
Zane
[Reply]  [No Email]
showcrop
08-06-2012 05:14:31
75.67.231.80
Get you a Sneaky pPete. I believe that they are sold on this site.
[Reply]  [No Email]
TOM N MS
08-06-2012 03:42:26
98.95.36.190
Probably gotta drop the crank. Might loosen all crank journal bolts and drop it down enough to do the trick without completely removing it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
