| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8N bogging down
[Return to Forum]
| Author |
[Modern View]
| ChrisFerguson
08-05-2012 12:38:01
70.192.197.253
8N sidemount. bogs down just riding across flat ground. i checked and points are good plugs are good. the firing order is goofy if i place it 1243 it wont even start put it 1234 it runs great which os when it bogs down when i start riding never seen anything like this. |
| old
08-05-2012 17:37:03
209.86.226.59
Re: 8N bogging down in reply to ChrisFerguson, 08-05-2012 12:38:01
| Sounds like you have a couple problems and a lack of knowledge. The points need to be set at 0.025 and the cylinders are numbered #1 up by the radiator and #4 back by the steering wheel. Only guessing on this but sounds like you think #1 is by the steering wheel and the #4 by the radiator which is back wards |
| Ultradog MN
08-05-2012 16:16:09
70.56.166.39
| If you pulled the distributer out are you sure you didn't replace it 180° out? You need to make sure it is on the compression stroke and not the exhaust stroke. |
| Bruce (VA)
08-05-2012 12:56:53
24.125.80.178
| | 6v or 12v? " i checked and points " What does that mean? Was the gap .025 w/o any pits or burning? " the firing order is goofy" No, not really. You're doing something wrong. The firing order is indeed 1-2-4-3, CCW. Had the distributor out lately? Messed w/ the timing? |
| chris ferguson
08-05-2012 13:05:07
174.252.113.233
Re: 8N bogging down in reply to Bruce (VA), 08-05-2012 12:56:53
| 12v I have the points gapped to .15 and look brand new the distributer was out and placed back in haven"t messed with the timing |
| chris ferguson
08-05-2012 13:10:28
174.252.113.233
Re: 8N bogging down in reply to chris ferguson, 08-05-2012 13:05:07
| Ok ill go back and try and adjust the timing |
| BillM (OH)
08-05-2012 13:08:15
173.81.81.180
| Points gap is .025 on a sidemount. If you had the sidemount distributor out, you have messed with the timing. As Bruce sez, firing order is 1-2-4-3, so timing is obviously not right. |
| chris ferguson
08-05-2012 13:27:10
174.252.113.233
Re: 8N bogging down in reply to BillM (OH), 08-05-2012 13:08:15
| Ok just did the timing and same deal on run on 1234 switch 1243. Nothing won't even start |
| Bruce (VA)
08-05-2012 14:30:31
24.125.80.178
Re: 8N bogging down in reply to chris ferguson, 08-05-2012 13:27:10
| | " 12v I have the points gapped to .15 and look brand new the distributer was out and placed back in haven"t messed with the timing " Why did you remove the distributor? That and the wrong gap is your problem. Gap is .025 on a sidemount. When you remove the distributor & put it back wrong, you change the timing. Remove the #1 spark plug. Ignition off, place your thumb over the #1 spark plug hole and crank slowly until compression is felt. Continue to crank the engine until you see the timing mark, 0* (top dead center) on the flywheel through the timing hole in the right side of the bell housing. Use chalk on the flywheel to exactly align the 4 degree mark with the pointer. Set the point gap correctly! .025 on the high lobe of the cam. Insert the distributor. With the gears fully meshed, the rotor should point to the right front cylinder head bolt. If not, remove it & try again until the proper rotor position is obtained. Rotate the distributor housing counter clockwise until the points are closed. Put the cap on & double check the plug wires, 1-2-4-3, CCW. Then, remove the primary wire from the side of the distributor (or at the coil, whichever is easier) Put one lead of your VOM (set on resistance) on the stud on the side of the distributor & the other on the block or other good ground. Slowly turn the distributor. The needle will move as the points close & then open. Find the exact spot just as the points open & then tighten down the distributor. Once the engine starts & gets to operating temp, and the idle is below 500 rpms, you can put your light on it to check the dynamic timing. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
