| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: 3 point drops
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Dell (WA)
08-01-2012 11:25:20
97.113.108.140
ET HUGEN........you do know yer internal hydraulic pump is driven by the tranny PTO shaft don't you? And everytime you clomp yer clodhoppers on the clutch pedal, yer PTO pump stops pumping. When the pump stops pumping, guess what??? yer 3-point hydraulics stop lifting. HOWSOMEVERS: there is a pressure relief valve that is supposed to hold the pressure when you clutch. There are several other causes for 3-point drop including the standpipe and amazingly enuff, yer 3-point hydraulic cylinder. A good 3-point lift will lift 800lbs and will hold up for 4-hrs. ALWAYS keep yer implements on the ground for SAFETY sake ........Dell |
| ET HUGEN
08-01-2012 11:31:16
71.7.3.83
Re: 3 point drops in reply to Dell (WA), 08-01-2012 11:25:20
| should i start by replacing the safety relief valve then ? |
| old
08-01-2012 12:43:54
209.86.226.27
Re: 3 point drops in reply to ET HUGEN, 08-01-2012 11:31:16
| First thing to do is pull the right hand inspection cover off the one with the dip stick. Fire it up and if you can have something on the 3 point. Lift it up and look for drips from the cylinder which will be from up high and also look for areas that you see a lot of fluid movement |
| Bruce (VA)
08-01-2012 11:34:54
24.125.80.178
| | " should i start by replacing the safety relief valve then ? " No You should start by troubleshooting the problem. |
| ETHUGEN
08-22-2012 09:35:20
71.7.3.83
Re: 3 point drops in reply to Bruce (VA), 08-01-2012 11:34:54
| I removed the inspection cover and when liftin a heavy blade i noticed alot of fluid coming down from above, so much so that it was pouring out of the 2 o clock bolt hole. I could not see in there very easily. do you use a mirror to inspect in there ? |
| Bruce (VA)
08-22-2012 12:48:04
24.125.80.178
Re: 3 point drops in reply to ETHUGEN, 08-22-2012 09:35:20
|   Good troubleshooting. But you do not need a mirror. You've seen all you need to see. Chances are very, very good that you have a worn lift piston and/or cylinder. Chances are less that it's a gasket. You can pull it down & see if it's the lift piston or the cylinder. Or you can just order all the parts and be done with it. Before you start, it would be a wise move to get a jig from Zane Sherman to adjust the internal linkage. And, make a couple of “guide studs” by cutting the heads off of two 7/16-14 x 3 5/8” bolts. Also, if your lift cylinder rebuild kit has the leather washer, get CNH part number 87051231 which is the neoprene washer for the lift piston instead of the leather one. The lift cover weighs nearly 100 lbs with the upper lift arms attached, & is very hard to maneuver. An engine hoist is an excellent idea. Remove the seat and spring, disconnect the upper lift arms at the knuckles. Remove the 14 bolts that hold the cover to the housing. (note that there are three different lengths) DO NOT remove the four nuts under the seat! Remove the right side inspection cover so you can remove the control rod tip from the pump intake valve. Lift the back of the cover straight up and slide a piece of wood under the cover to keep the tip of the control rod out of the rocker shaft. Once you are sure the control rod is out of the rocker shaft, you can then remove the cover. Turn the cover upside down, remove the four bolts that hold the cylinder to the cover, & use a little compressed air on the cyclinder to remove the piston. Check the cylinder for excessive scratches, hone if necessary. Install a new piston with "0" ring and backing washer in the cylinder. Install the CNH neoprene washer w/ the concave side toward the “O” ring. At this point, check the cam follower pin & the control rod. If the cam follower pin is worn replace it. Then, if you have a jig, adjust the linkage to specs. The ‘shade tree’ adjustment was to bend the control arm to compensate for normal wear in the linkage, springs & cam follower pin. If the control rod is bent, remove it & straighten it. (very carefully; they break easily!) Replace the gaskets under the cylinder and bolt it back on the cover. Put the gasket on the tractor (no sealer) and put the gude studs in place. Unless you do this every day or have eyeballs in your finger tips, get some help to guide the tip of the control arm back into the rocker shaft. (this is the point you will wish you had a engine hoist to hold the top cover while the control rod dances around the intake valve arm on the pump!) Align the cover holes up with the housing holes. Remove the guide studs. Tighten cover bolts, connect lift arms install the seat. Re-install the inspection covers with new gaskets. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
