| Author |
[Modern View]
| Britcheflee
07-31-2012 06:46:39
67.187.170.181
Is it possible for the valve adjustment to move once set on an 8n? If valves need re-checking is it more likely they have become too loose or is there any way the gap could become smaller? What are typical symptoms of incorrectly adjusted valves on these tractors.
Thank you
Lee |
| Hobo,NC
08-01-2012 08:28:18
98.16.5.216
Re: Valves question in reply to Charner, 07-31-2012 06:46:39
| gdstogner
08-01-2012 07:24:37
207.191.126.206
Re: Valves question in reply to Britcheflee, 07-31-2012 06:46:39
| If adjusting bolts are loose could you use blue loctite after adjustig them.Thank you and have a blessed day. |
| TheOldHokie
08-01-2012 03:38:23
108.8.17.88
Re: Valves question in reply to R Geiger, 07-31-2012 06:46:39
| Quoting Removed, click Modern View to see
Yeah - my Celica 8RC engine used a screw type adjuster on the valve stem end and it required periodic tweaking. IIRC a solid foot on the other end of the rocker ran directly on the cam just like a lifter.
TOH |
| Hobo,NC
07-31-2012 18:46:29
98.16.5.216
Re: Valves question in reply to TheOldHokie, 07-31-2012 06:46:39
| All the engines I have been into the used disk type adjuster I have never seen one get out of adjustment... I rebuilt the engine in my 93 yota cilica 250K the adjustment on the valves were dead nutzz.... I did not cut the seats are valves,,, I don't think I have anything that would cut the seats anyways they are that hard...
Engines that use disk,,, the disk rotates as the lobe enters it no hammer affects as with s-cre-w type lash adjusters...
This post was edited by Hobo,NC at 18:48:24 07/31/12 3 times. |
| TheOldHokie
07-31-2012 16:56:02
108.8.17.88
Re: Valves question in reply to Bruce (VA), 07-31-2012 06:46:39
Interesting - I did some research (Google is your friend) and it does seem that different vehicles/engine designs go different directions. Based on the comments/stories I found newish motorcycle engines seem to be prone to tightening for some reason and old pushrod OHV enginse seem to go the other way. I know my old Falcon and Triumphs required regular adjustment to keep them quiet as did my "modern" 73 OHC (8RC) Toyota. The 9N was a clatter box before I put in adjustable lifters and neither it or the "new" 8N have logged enough hours to judge how they will change. Since I sold that Toyota 35 years ago I don't think I have owned an OTR vehicle without hydraulic lifters. The longer I'm around the more I learn what I don't know ;-)
TOH |
| HCooke
07-31-2012 17:58:37
70.195.0.168
Re: Valves question in reply to TheOldHokie, 07-31-2012 16:56:02
| My experience with 356 Porsches in the 70's. Valve clearance needed to be adjusted every 6000 miles! They always loosened up. |
| JMOR
07-31-2012 14:55:56
99.105.24.57
Re: Valves question in reply to Brad Buchanan, 07-31-2012 06:46:39
Hobo,NC said: (quoted from post at 15:14:51 07/31/12)
TheOldHokie said: (quoted from post at 20:41:30 07/31/12)
| Roger in Iowa said: (quoted from post at 12:19:58 07/31/12) The gap gets narrower because the valve/valve seat area wears. |
That's an interesting concept Roger and I am sure there is some slight face/seat wear. But valve seats often carbon up and don't fully close increasing valve lash. And which wears faster - valve seat/face or the face of the cam lobes/lifter/stem end? I have adjusted a lot of valves on many different vehicles when they started getting noisy because the lash was excessive. ABICR the only time I have ever seen the gap too narrow is when someone screwed up the adjustment.
TOH |
I have seen it work both ways,,, I would say allot depends on if it has harden seats then it would depend on how hard they are... I would venture to say the more moving parts in the valve train the more apt you will find them lose... You will still find it both ways across the board on different engines... | On all the old Ford & Chevy OHV engines I have worked on they seemed to grow the gap, BUT two different Honda 200X ATCs, they would close up & eventually hold the valves open. Maybe something to do with aluminum or OHC or the large amount of moving parts in those old OHV engines.
By the sounds of my 8N right now, I say that its gaps have opened up.
This post was edited by JMOR at 14:57:31 07/31/12. |
| Hobo,NC
07-31-2012 12:14:51
98.16.5.216
Re: Valves question in reply to kornfused, 07-31-2012 06:46:39
| TheOldHokie
07-31-2012 09:41:30
108.8.17.88
Re: Valves question in reply to G6 at Snook, TX, 07-31-2012 06:46:39
TOH |
| carolina don
07-31-2012 09:09:20
70.60.100.86
| If you have adjustable lifters...the adjusting screw threads may be worn and letting it back off.May need to check them and replace lifter[s] if necessary. don b |
| TheOldHokie
07-31-2012 08:44:43
108.8.17.88
Re: Valves question in reply to Greg 2N (TX), 07-31-2012 06:46:39
Funny - I always thought the gap widened and they got noisy as the lifters/rockers/stems wore. That's why they are adjustable :idea:
TOH |
| carolina don
07-31-2012 09:01:59
70.60.100.86
Re: Valves question in reply to TheOldHokie, 07-31-2012 08:44:43
| Yeah Dan.....we learn more about these tractors every day.Something special about how tractor valves work.Huh? don b |
| Dell (WA)
07-31-2012 07:57:11
97.113.109.107
| Lee........you ask......."do valves need re-checking".......as a general rule, they seldom move and when they do the gap gitts NARROWER. Too narrow a gap on yer exhaust valve and you will BURN yer valve and loose compression. Too narrow on yer intake and it will "pop" thru the carb. But to answer yer original question, yes, valve gaps do change over time but usually they do not need re-adjusting after installation. Don't fergitt, there are 2-types of N-Engine valves. Early valves have "trumpet" ends and you actually haffta "grind" the end of the valve for clearance. Later 8N's have adjustable valve lifters and you need "knuckle-buster" wrenches to adjust them. Personally, I prefer blonde wrenches 'cuz I don't like to squeeze blackheads .......Dell, the wrencher |
| Roger in Iowa
07-31-2012 09:19:58
166.182.3.145
Re: Valves question in reply to Dell (WA), 07-31-2012 07:57:11
| ZANE
07-31-2012 15:45:19
98.83.14.93
Re: Valves question in reply to Roger in Iowa, 07-31-2012 09:19:58
| | That is the correct answer!!! Zane |
