Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Suction Line Strainer Source
[Return to Forum]
cmcgalla
07-30-2012 05:31:46
50.41.135.76
Hi, I need a 1.5"X3" suction liner strainer for my backhoe, it is just a metal screen, is this a standard part I can find at Napa or TSC? I am not finding anything online, I must be searching wrong?
[Reply]   [No Email]
Den N Ms
07-30-2012 13:41:04
184.41.143.48
 Re: Suction Line Strainer Source in reply to cmcgalla, 07-30-2012 05:31:46
Cmcgalla,You might check here!
[Reply]  [No Email]
ZANE
07-30-2012 12:48:20
98.83.103.81
Why not just clean and re use that one???
That is what it is designed to do with it.
Zane
[Reply]  [No Email]
TheOldHokie
07-30-2012 08:19:51
108.8.17.88
 Re: Suction Line Strainer Source in reply to Ultradog MN, 07-30-2012 05:31:46
cmcgalla said: (quoted from post at 10:35:21 07/30/12) so you don't think reducing the line size in order
to put in an inline strainer will be a problem?
Regardless of the size of the hose your effective suction line siize is the SMALLEST of the components in that plumbing run. And from the looks of the picture that is 1" or smaller pipe. A 1" or 1-14" NPT filter head and 100 mesh stainless steel strainer should work fine.
TOH
This post was edited by TheOldHokie at 12:50:14 07/30/12.
[Reply]  [No Email]
TheOldHokie
07-30-2012 07:01:04
108.8.17.88
 Re: Suction Line Strainer Source in reply to Creeksideva, 07-30-2012 05:31:46
Look up Y type hydraulic strainers. Unlikely you will find a replacement element for your existing strainer but complete strainers are avaialble staring at around $50. Your line is reduced considerably after the strainer or so I'm not sure what the flow rate is. A 1" or 1-1/4" NPT spin-on head and filter should be more than adequate and runs about $50 as well.
[Reply]  [No Email]
cmcgalla
07-30-2012 07:35:21
50.41.135.76
 Re: Suction Line Strainer Source in reply to TheOldHokie, 07-30-2012 07:01:04
[Reply]  [No Email]
TheOldHokie
07-30-2012 06:13:35
108.8.17.88
 Re: Suction Line Strainer Source in reply to Arthur L.Strader Jr., 07-30-2012 05:31:46
The screw-in tank strainers like the one below are a common item but I've never been able to find replacements for the old OEM strainers that are insde the line itself. If you can't use an in tank straiiner one possible solution is to mount an external spin on type filter head on the outside and use a cartridge type wire strainer.
TOH
[Reply]  [No Email]
cmcgalla
07-30-2012 06:27:47
50.41.135.76
 Re: Suction Line Strainer Source in reply to TheOldHokie, 07-30-2012 06:13:35
Well it goes inside this "y" that I have attached a
pic of. Not sure how I would use a spin-on style,
since that suction line is about 2" O.D. could I step it down without creating a problem?
I don't know much about hydraulics, but I would say that strainer is not helping my performance . . . what say you?
[Reply]  [No Email]
Bill Rowles
07-30-2012 07:03:00
76.2.232.129
 Re: Suction Line Strainer Source in reply to cmcgalla, 07-30-2012 06:27:47
I would not "step it down" in size, but i would try to clean it in solvent and blow it out real good with compressed air if I could not find a replacement. Don't operate the system without a strainer/filter or you will have many control valve and pump problems as the sump trash travels through the system.
[Reply]  [No Email]
cmcgalla
07-30-2012 07:33:46
50.41.135.76
 Re: Suction Line Strainer Source in reply to Bill Rowles, 07-30-2012 07:03:00
well the problem is the screen is cut and damaged . . .
[Reply]  [No Email]
Bill Rowles
07-31-2012 05:32:19
76.2.232.129
 Re: Suction Line Strainer Source in reply to cmcgalla, 07-30-2012 07:33:46
If the filter screen is cut, get some fine wire(preferably stainless steel) and "sew" it back together best you can....even a slightly cobled-up filter/strainer is better than none. Maybe you can find a replacement later but can still work the tractor till then.
[Reply]  [No Email]
cmcgalla
07-31-2012 14:53:40
50.41.135.76
 Re: Suction Line Strainer Source in reply to Bill Rowles, 07-31-2012 05:32:19
that is exactly what I did . . . . thanks guys
[Reply]  [No Email]
cmcgalla
07-30-2012 06:34:38
50.41.135.76
oops. . . attached I hope
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
