| Ford 9N, 2N & 8N Discussion Forum |
Topic: NAA rear axle question
[Return to Forum]
| Author |
[Modern View]
| nkcarizona
07-28-2012 11:35:07
66.235.228.120
I posted this message on the newer Ford tractor forum, but as the NAA and 8N have basically the same rear axle I am posting here as well.I just installed new brakes,left axle and hub on my NAA. When adjusting the brakes with the left wheel off the ground, the right on the ground and the transmission in neutral, I expected to be able to freely turn the left wheel. However, after a 1/4 to 1/2 turn the wheel stops and acts like it wants to turn the right wheel. When I jack up the right wheel as well, then after the partial rotation both wheels turn together in the same direction. Is this right or is something busted in the differential? There is no grinding or clunking when both wheels turn. With both wheels off the ground and in gear, the wheels turn in opposite directions as expected. |
[Reply] [No Email] | |
| nkcarizona
07-29-2012 10:48:02
66.235.228.120
Re: NAA rear axle question in reply to nkcarizona, 07-28-2012 11:35:07
| | Here is the latest. This morning I jacked up both wheels put it in gear and turned the right wheel. Initially it jammed after a partial rotation, but a couple of gentle jogs got past that and it turned freely with both wheels rotating in opposite directions. Now, in neutral both wheels turn freely without obstructions. What now? Do I assume everything is ok, or tear into it to look into the diffy? If time and effort were no object I would take it apart. Any votes on which way to go? |
| Royse
07-29-2012 07:59:57
69.36.49.151
| Hopefully it's just the brake shoes catching, but hard to tell from here.
Does it stop after 1/2 turn with the shoes removed? |
| Royse
07-28-2012 18:56:11
69.36.49.151
| Ditto. Sounds like a shim or tree.
Check out John Smith's site on doing the rear axle seals.
He lays it out pretty well.
Poke Here |
| nkcarizona
07-29-2012 07:29:02
66.235.228.120
Re: NAA rear axle question in reply to Royse, 07-28-2012 18:56:11
| | I did look at Smith"s site and thought I had shimmed the axle properly. I replaced the two original metal shims and had to add a paper shim to get free play of .010 inch (measured with dial gauge). I did not rotate the axle at this point to check that I had the clearance at all positions. Is it possible that something is caught between the two axle ends? I am afraid that something has come apart in the differential, as it stops abruptly when the approximately 1/2 turn of free play is used up. Looks like I will be taking things apart. |
| mhb@ufe
07-29-2012 07:59:46
184.153.187.144
Re: NAA rear axle question in reply to nkcarizona, 07-29-2012 07:29:02
| | Do the axles both turn together all the time or just after the half turn of free play? If it has a half turn of free play before the axles turn together I would be concerned about a problem in the differential assembly. You might want to pull the left axle trumpet so you can pull the differential out and inspect it. Mark |
| nkcarizona
07-29-2012 08:19:26
66.235.228.120
Re: NAA rear axle question in reply to mhb@ufe, 07-29-2012 07:59:46
| They only turn together after the free play. I think you are right that something is messed up in the differential. I am trying to get my head around the need to get into the diffy. |
| mhb@ufe
07-28-2012 14:30:07
184.153.187.144
| | When you replaced the axle you must not have shimmed the axle bearing retainer to set the proper preload on the axle bearings and the axles are too tight where they come together inside the differential. Mark |
| Dell (WA)
07-28-2012 11:42:50
97.113.109.107
| nkcarizona........you complain BOTH axle turn the same direction. That means they are touching inside the diffy. You need a "shim" between yer axle trumpet mouth and yer axle bearing. You can no longer gitt metal shims but the cardboard shim works just as good. ........Dell |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
