Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: No Power on 2N
[Return to Forum]
Tomfromcad
07-28-2012 07:40:01
24.247.132.54
Just changed carborator, and when pulling the disc, tractor stutters, backfires and has no power. Don't know what to do....
[Reply]   [No Email]
Den N Ms
07-28-2012 10:37:29
184.41.143.48
 Re: No Power on 2N in reply to Tomfromcad, 07-28-2012 07:40:01
Tomfromcad ,Try opening your down pointing main carb jet 1/2 to one turn and try that.
[Reply]  [No Email]
Dell (WA)
07-28-2012 08:43:25
97.113.109.107
Tom........gonna need more info. 6-or-12V, last time you changed yer points (0.015")
keep yer itchy-twitchy fingers off'n them handy-dandy carb tweek'ums.
You do know ittza 2-bolt, 15-min job to remove yer weird 4-nipple front mount dizzy to change and adjust the points (0.015") on the kitchen table, don't you? Just un-snapple yer capple and letter dangle. Installation is a reversal of the removal ...except... finger start yer 2-bolts and then install yer rotor while rotating the rotor until the OFF-SET tang drive fits the OFF-SET camshaft drive slot. Now tighten yer 2-bolts and re-snapple yer capple. Simple, eh?
Remember to "polish" the INVISIBLE corrosion from between the points before installation. Me? I clamp a clean $1-bill between the points and pull. Iff'n yer really cheap, tear a strip of HEAVY brown paper grocery sack and use that. .........Dell, yer memory challenged sparkie-meister
[Reply]  [No Email]
Tomfromcad
07-28-2012 08:58:24
24.247.132.54
 Re: No Power on 2N in reply to Dell (WA), 07-28-2012 08:43:25
12v, changed coil and points (adjusted points to .015 ) All new. Tractor runs good while in idle or not under a load. New carborator installed.
[Reply]  [No Email]
Dell (WA)
07-28-2012 11:38:04
97.113.109.107
 Re: No Power on 2N in reply to Tomfromcad, 07-28-2012 08:58:24
Tom........didja know that the N-Engine is SOOOooo GOOOoood that it will run on just 2-sparkies but won't have enny power just as you complain??? Usually nuebie shadetree mechanics swap sparkies 3&4. Starts eazy but NO power to pull.
Didja know that yer NEW carborator does NOT come adjusted right outta the box??? Set yer down-pointing main jet to 2-turns and LEAVITT!!!
Adjust yer side-pointing idlemix for FASTEST idle, NOT SMOOTHEST idle. Understand the difference??? The side-pointing idlemix is BASSACKWARDS, out fer lean, IN fer ENRICH. Last time I adjusted my eazy starting 6V-8N Marvel/Schebler carb, the side-pointing idlemix was 1/4-turn. Yers should be simular. ........respectfully, Dell sparkie-meister
[Reply]  [No Email]
Mike OH
07-28-2012 09:05:18
173.89.186.132
Recheck your spark plug connections.1,2,4,3 CCW.
[Reply]  [No Email]
Tomfromcad
07-28-2012 09:32:06
24.247.132.54
 Re: No Power on 2N in reply to Mike OH, 07-28-2012 09:05:18
Checked plugs. Tractor runs fine until I try to pull the disc. Then loses power. Just installed a new carburetor. That's when the trouble started.
[Reply]  [No Email]
old
07-28-2012 11:17:16
209.86.226.40
 Re: No Power on 2N in reply to Tomfromcad, 07-28-2012 09:32:06
Does choking it help or hurt it?? If it helps your running to lean if it hurts your running to rich and either one will cause power loss. Also check your air cleaner it is the most neglected part of most tractors. If it is full of dirt or water or low on oil it can cause funny problems
[Reply]  [No Email]
TOM N MS
07-28-2012 10:37:49
98.95.26.125
Will it take gas when you give it throttle quickly? If not, try turning your main adjustment needle on the carburetor OUT(CCW)1/4 turn then try to give it gas Fast--if it takes gas good when going quickly from idle to fast, you should see it perform different under load.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
