Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 3pt dirt scoop levelling
[Return to Forum]
Oldmanbishop
07-23-2012 07:11:44
134.198.180.10
I just hooked up my 3pt dirt scoop (facing forward) to my 9n, and I"m having some trouble moving manure. I adjusted the toplink so that it scoops the manure fairly well, but when I pick the scoop up the manure mostly falls out since the 3pt causes it to tip forward.
Is there some 3pt trick that I"m missing? I could just use it backwards, but the reverse gearing is fairly fast and I"d rather not push with the 3pt.
Thanks!
[Reply]   [No Email]
NoNewParts
07-24-2012 11:27:07
67.240.145.25
 Re: 3pt dirt scoop levelling in reply to Oldmanbishop, 07-23-2012 07:11:44
like others have said, all dirt scoops aren't equal
with their geometry.
Ford/Arps/Dearborn ones seem to work much better
than the new copies.
Light work like manure and piles of material, I use them in reverse
with sway bars on to help with the strain/impact.
And don't 'ram' too hard.
Digging dirt, or packed material, you're right,
tractor pulling forward is how tractors were designed.
I have a Ford scoop at the moment and am cleaning the muck
out of my water hole (good summer for it, not too much water to drag out with the blade)
scoop forward, full up on a 8N and it stays pretty level.
Now if I could just figure out how to keep the front end on the ground when I drive up and out :)
edit BTW started the job with a big $ modern small loader tractor-30hp-4wd.
HA! loader wouldn't hardly scratch my hard packed clay. switched to the
old Ford and its $100 scoop and getting it done...
I'll use the loader to move the dirt the 8N hauls up.
ya, I know a loader isn't designed for digging, but it's still surprising
how well that old Ford does compared to the new one.
This post was edited by NoNewParts at 11:38:25 07/24/12.
[Reply]  [No Email]
Ken in Mi
07-24-2012 09:33:09
68.255.205.20
these are good replies, I would like to know why you put it on facing forward. That means you are driving into the manure to scoop it. My wifeee wouldn't let me put may 8N back in the garage if I did that....
[Reply]  [No Email]
Oldmanbishop
07-24-2012 11:25:24
173.86.31.132
 Re: 3pt dirt scoop levelling in reply to Ken in Mi, 07-24-2012 09:33:09
Fortunately we don"t have a garage to get dirty. I like to have it front-facing so it is easier on the 3pt. The horses also tend to spread/trample the pile, so it isn"t hard to get over.
[Reply]  [No Email]
kornfused
07-23-2012 15:27:14
69.149.222.155
"It seems like the problem is that the 3pt tilts the implement as it picks it up due to the position of the toplink " excatly, try adjusting the top link with it empty. When I raise my scoop it tilts back - full or empty.
[Reply]  [No Email]
Billybuck
07-23-2012 12:29:31
171.161.160.10
You might try adding two "telescoping links" at the scoop/top link, as pictured on this Wood RM-59 mower. They alow the impliment to drop level to the ground and remain level as the impliment is raised, by shortening the overall length when dropped and lengthening when raised. They are part number 24091 on Messick's site or could easily be fabricated.
[Reply]  [No Email]
Oldmanbishop
07-23-2012 14:19:37
173.86.31.132
 Re: 3pt dirt scoop levelling in reply to Billybuck, 07-23-2012 12:29:31
Thats great. Thanks!
[Reply]  [No Email]
HCooke
07-23-2012 08:48:29
70.195.2.7
I have moved gravel by reversing the scoop and going back into the pile. (Also a KK scoop)
[Reply]  [No Email]
Ron-MO
07-23-2012 07:42:09
63.87.140.3
My experience is that there is a fine line on adjusting the top link to where it will pick up the material going forward, yet not dump when you pick it up. Just a very slight tilt downward works for me, but it usually takes a bit to get the angle just right.
[Reply]  [No Email]
Ron-MO
07-23-2012 07:45:32
63.87.140.3
 Re: 3pt dirt scoop levelling in reply to Ron-MO, 07-23-2012 07:42:09
My scoop is a King Kutter, and I am sure different scoops work slightly different. I usually start level, then keep adjusting until it just starts to dig when going forward.
[Reply]  [No Email]
Oldmanbishop
07-23-2012 07:47:56
134.198.180.10
 Re: 3pt dirt scoop levelling in reply to Ron-MO, 07-23-2012 07:45:32
Thanks, mine is a KK as well. Maybe I'll try working more to get the tilt right.
[Reply]  [No Email]
dhamps10
07-23-2012 07:38:49
50.103.137.101
I have found some scoops just don't work. Others work good.
Dennis
[Reply]  [No Email]
Oldmanbishop
07-23-2012 07:41:35
134.198.180.10
 Re: 3pt dirt scoop levelling in reply to dhamps10, 07-23-2012 07:38:49
It seems like the problem is that the 3pt tilts the implement as it picks it up due to the position of the toplink and arms.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
