| Author |
[Modern View]
| Ken(Ark)
07-22-2012 17:26:52
173.187.231.61
| 52Redbelly
08-21-2012 13:43:20
209.244.4.189
Re: Custom made N tractor spin on oil filter adaptors . in reply to Ken(Ark), 07-22-2012 17:26:52
| [URL=http://s1065.photobucket.com/albums/u388/carymcdaniel1/?action=view¤t=Spinonfilter.jpg][/URL]
Here is what it looks like on my 8N |
[Reply] [No Email] | |
| David Bean
08-19-2012 13:55:19
24.126.223.218
| Wonder if it will fit a Jubilee? I like the vertical orientation. |
| JMOR
08-18-2012 20:34:26
72.181.173.171
Re: Custom made N tractor spin on oil filter adaptors . in reply to Chris Ferguson, 07-22-2012 17:26:52
| Quoting Removed, click Modern View to seeAn N isn't a Cummins. "Not as critical', as in Priming makes absolutely ZERO difference on an N as far as engine bearings are concerned. Study the oil circuits. |
| carlntexas
08-18-2012 18:08:45
69.46.56.131
Re: Custom made N tractor spin on oil filter adaptors . in reply to TheOldHokie, 07-22-2012 17:26:52
That looks really well made I bought one that the filter screws on the side. It is made well and uses same holes as the canister, but I found out from this site the orifice is to big. I took it back off and drilled an tapped for a 8x32 screw. cut the head of screw and drilled a .062 hole slotted it for screwdriver. I screwed it in with a little red loctite this raised my OP about 5lbs. |
| 52Redbelly
08-18-2012 15:41:10
166.147.121.155
| Ok, I bought one of these. Very well made and bolts right up with original fittings. Looks good too. |
| Bob - MI
07-23-2012 14:43:12
71.10.142.106
| | Very nice workmanship. I like to see folks that recognize a problem and find a good solution to it. Now if he just made one for a 20HP Kohler twin I would be all set. |
| BillM (OH)
07-23-2012 09:08:31
173.81.81.180
| Neat piece of work. Must work for free and no depreciation on the CNC for that price! |
| TheOldHokie
07-23-2012 03:24:46
108.8.17.88
Re: Custom made N tractor spin on oil filter adaptors . in reply to flembo, 07-22-2012 17:26:52
Do you prime the full flow oil filter on your cars and trucks? For all practical purposes it's a non-issue either way.
TOH |
| jimmy j j
07-24-2012 12:34:44
204.54.36.245
Re: Custom made N tractor spin on oil filter adaptors . in reply to TheOldHokie, 07-23-2012 03:24:46
| | I don't read it as they claim you'll destroy your engine if you don't prime the filter. Plus, on an N, it's not as critical since it's a bypass filter. It's just a nice added feature of orientating the filter that way. I wouldn't get hung up on it. That aside, when the orientation allows, filters should be primed prior to installation. Per Cummins: "Fill the oil filters with clean lubricating oil when changing the engine oil to ensure immediate bearing lubrication when restarting the engine. Failure to pre-lube the oil filter may cause bearing damage." |
| 52Redbelly
07-25-2012 16:44:09
166.147.120.17
Re: Custom made N tractor spin on oil filter adaptors . in reply to jimmy j j, 07-24-2012 12:34:44
| I fill mine on my F350 truck. Because I can. |
| cj in Michigan
07-22-2012 21:57:41
24.247.148.35
| A repurposed compression fitting? |
| Ken(Ark)
07-22-2012 18:34:36
173.187.231.61
Don't forget the free shipping .
I like the old style canisters myself but I give kudos to a man making an upgrade basically free ( minimum wages even ?) and helping the hobby for the rest of us . Reminds me of that nice guy from windy ridge farms . :wink: |
| TheOldHokie
07-22-2012 18:25:42
108.8.17.88
Re: Custom made N tractor spin on oil filter adaptors . in reply to GB in MT., 07-22-2012 17:26:52
Zero would be my guess. Remember the oil goes through the bearings by a totally different route. Only "excess" oil that doesn't go through the bearings goes through the filter and that is via the 1/16" restrictor passage in the OEM filter canister.
As for price that chunk of aluminum would cost me $20 before I ever made the first chip and the little JIC adapter another $5.
TOH |
| Royse
07-22-2012 18:08:22
69.36.49.151
| Bruce, did you forget to use the "sarcasm font"? :lol:
I have a parts tractor out here with a spin on adapter I've been meaning to take off.
At $40 each maybe I'll use it as a pattern and have some made. |
| Bruce (VA)
07-22-2012 17:57:47
24.125.80.178
| | I'm glad to see that it is "orientated" correctly. And I wonder how many N engines I've ruined because I didn't " "prime" the oil filter by filling with oil prior to installation". |
| DrLarryE
07-22-2012 18:36:17
68.60.77.15
Re: Custom made N tractor spin on oil filter adaptors . in reply to Bruce (VA), 07-22-2012 17:57:47
| Would the priming be an issue with other tractors? If he makes these for other types he might be just assuming an N is the same |
| TheOldHokie
07-22-2012 17:32:06
108.8.17.88
Re: Custom made N tractor spin on oil filter adaptors . in reply to old, 07-22-2012 17:26:52
Very nicely made!!! CNC beats the pants off cranking it yourself.....
TOH |
