My 1950 8n stalls after 5-15 minutes. The stall has happened 6 times and always under load while using a 5 foot rotary cutter in 2-3 foot grass (the cutting and tractor move effortlessly). Restart is never immediate and fails from anywhere between 4 hours and 4 days. Prior to any stalling of this nature, I replaced the fuel tank, sediment bowl, fuel lines, and replaced the carburetor with a new one when the rebuild carb did not work out. The fuel system was replaced because it was the original and full of rust causing the fuel flow to be a trickle and only allowing the tractor to use fuel immediately in the carb before stalling. The fuel system replacement was a great fix for 2 weeks when not under load and driving the tractor for approximately 16 miles at different speeds in all gears. Stalling after the fuel system replacement was always under load and could possibly happen when not under load, but I did not have the opportunity to discover whether that can happen when not under load.
Initially, I thought the coil was getting hot, so I replaced the coil and the tractor would not start. I had a new set of plugs, wires, condenser, rotor, points, and cap that I changed to (the previous rotor, points, and condenser were new two months prior) and still the tractor would not start. The ignition switch is two months old and seems to work as it does complete the circuit and I can see spark. The fuel system is fine with a steady flow to the carb. Voltage is fine, getting spark to the coil and distributor with gap set at .025 as usual on 216 plugs and points. The tractor was down for 2 days before I was able to start it and get it on trailer. I’m thinking replacement of the wire harness, but why spend money that doesn’t need spending if the fix could be lesser… Anyone have ideas to the issue of stalling under load and failure of a restart that appears random when it will start? The tractor is 6 volt with the side distributor.
