Topic: Another 'why wont it start' thread
[Return to Forum]
| Author |
[Modern View]
| bgarrett
07-20-2012 19:55:17
166.249.196.228
Freshly rebuilt engine, 1941 9N, has voltage to the new coil, hot battery, no spark at the plugs. The distributor has new bushings and shaft, new points set at .015 and the condenser tests good. I used the meter to check continuity thru the distributor, no grounds. Its 12V and I am using the resistor. Whats left? |
| bgarrett
07-21-2012 20:02:57
166.249.194.91
Re: Another 'why wont it start' thread in reply to soundguy, 07-20-2012 19:55:17
| oops, duplicate post
This post was edited by bgarrett at 20:04:25 07/21/12. |
| Royse
07-21-2012 16:49:36
173.15.30.106
Re: Another 'why wont it start' thread in reply to bgarrett, 07-20-2012 19:55:17
| You're welcome!
Glad you got it up and running! |
| bgarrett
07-21-2012 08:39:07
166.249.201.68
Re: Another 'why wont it start' thread in reply to Charles (MO), 07-20-2012 19:55:17
| Quoting Removed, click Modern View to see
Your line of thinking led me straight to the problem. Thank you Royse!
I was sure the coil spring was contacting the brass screw but what about the other contact on the coil? It was straight and measured 7/8" from the edge but the matching contact on the distributor cap is about 3/8 or 1/2" from the edge so I bent the contact strip on the coil into a U shape and checked for spark. Got a big fat spark and the engine fired up and ran good!!
I was about ready to scream yesterday, (The 100 degree temperature out there made things worse)
I appreciate this forum and everyone who is willing to offer help. Thanks guys! |
| Royse
07-20-2012 20:25:05
50.104.146.44
| The meter from where to the points shows continuity? If you're going from the top of the coil to the points, that would also include the spring. It just makes contact with the brass screw when you clamp the coil on top of the distributor, and some times does not make a good connection.
If you can turn the motor over while measuring continuity from ground to the top of the coil, key off of course, that measurement should fluctuate too. No continuity when the points are open, just a few ohms of resistance when they are closed. |
| bgarrett
07-20-2012 20:14:49
166.249.196.228
Re: Another 'why wont it start' thread in reply to GB in MT., 07-20-2012 19:55:17
| Thanks Royse. What about the spring at the bottom of the coil?
The meter says the brass strip has continuity to the points so what else can I check there?
| heybusdriver
07-21-2012 18:53:08
70.71.98.18
Re: Another 'why wont it start' thread in reply to bgarrett, 07-20-2012 20:14:49
| | Sure is a pretty motor, Stan
8N 146710 8N 179555 8N 197904 8N 199000 8N 254079 8N 362039 |
| bgarrett
07-21-2012 20:02:42
166.249.194.91
Re: Another 'why wont it start' thread in reply to heybusdriver, 07-21-2012 18:53:08
| Thank you
I am so old I expect my new parts to actually fit and work correctly
This post was edited by bgarrett at 20:03:35 07/21/12. |
| Royse
07-20-2012 20:04:53
50.104.146.44
| What is the voltage to the coil? Should be 12 volts with the points open, and drop when the points close.
If the voltage doesn't drop when they close they may not be making contact. Could be shipping oil on the new points that needs to be cleaned off.
Could also be the little spring that connects the coil to the brass screw or a couple of other things like the brass strip that connects them.
Nice looking work by the way! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
