| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8n - Rings stuck or broke...
[Return to Forum]
| Author |
[Modern View]
| dave404
07-18-2012 20:55:02
69.176.13.10
Been sitting for several yrs. got it started and running good. Shes smoking pretty bad at high speed in neutral. this evening i noticed oil around the exhaust pipe clamp. Stuck or broken oil rings? Ive not done a compression chk. how much atf to use and do i put it in the oil and fuel tank. i removed plugs and sprayed blaster in plug holes ,will let it sit overnight. |
| DollarBill
07-22-2012 02:12:56
98.70.214.144
Re: 8n - Rings stuck or broke... in reply to dave404, 07-18-2012 20:55:02
| Autolite 437's run a little hotter and may help with the spark plug fouling. |
| dave404
07-21-2012 11:43:10
69.176.13.10
| my valve not stuck, took side cover off. it was just open. going to try atf again. dont look too good, run it some more this morning and it starting fouling the plugs. will let sit overnight again since the other eve. #4 cylinder didnt get much atf. |
| bgarrett
07-21-2012 10:44:50
166.249.196.140
Re: 8n - Rings stuck or broke... in reply to soundguy, 07-18-2012 20:55:02
| my number 4 exhaust valve was stuck open and oil was running out the tailpipe |
| dave404
07-19-2012 18:00:16
69.176.13.10
| wasn't thinkin on last comment. valve on #4 open or stuck letting the atf go straight thru to carb.. |
| dave404
07-19-2012 11:31:24
69.176.13.10
| started it up today after sitting overnight with pb blaster in the plug holes and run it around the yard a little, no raw oil coming from exhaust clamp like yesterday. put some atf in gas tank as suggested. i will add some atf in the plug holes this eve. and let sit a couple days,as i got some more odds and ends to do. |
| dave404
07-19-2012 17:49:35
69.176.13.10
Re: 8n - Rings stuck or broke... in reply to dave404, 07-19-2012 11:31:24
| Bad news i guess ? this eve. i poured atf in the plug holes. on #4 cylinder, the atf went straight thru and came out the carb. broke rings ? |
| soundguy
07-19-2012 06:27:24
107.41.47.232
| | ditto what db said. and if you do add atf tot he oil.. do it right before you change the oil. IE.. add a quart of atf.. run her till warm, then drain. might want to get a few of the cheapy 3$ fram C3 filters on hand depending on how bad the oil looks.. if it comes out like chunky tar.. plan on some oil changes.. :) ps.. entirely possible to have bad oil ring and good compression rings. also.. can have bad compression and oil rings.. but comp may stay up due to the extra oil sealingthe comp rings. etc. |
| DollarBill
07-19-2012 02:48:07
98.70.214.144
| Remove the spark plugs and put 4 ozs in each cylinder - Let is sit for several days, turn the engine over and repeat. Spin the motor with the plugs out to flush the cylinders before attempting to start.
Mix a quart of ATF with five gallons of gas. I would not recommend putting ATF in the crank case - There's no telling how gunked up the crank case and the last thing you want is to clog the oil pump screen. A more conservative approach would be frequent oil changes using High Detergent oil - Change it and the filter when the oil turns black. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
