Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 46 2N 12V conversion problem
[Return to Forum]
Tom Beddard ENC
06-14-2012 18:13:08
173.219.96.189
46 2N-frontmount dizzy- I did a 12v conversion using JMOR s diagram keeping 6v coil & adding 2nd resistor. I missed the part abouting add the "diode or idiot lamp" & could not shut off tractor unless I unplugged the excite wire. Is this because the "diode or idiot lamp" that is not installed? I found that if I moved the excite wire to the bottom/middle post on the original dash mounted resistor it worked right. Is it ok to use it like this? If not where do I get the diode or idiot lamp & what is a "idiot lamp"
[Reply]   [No Email]
Dell (WA)
06-14-2012 21:36:44
71.217.30.27
 Re: 46 2N 12V conversion problem in reply to Tom Beddard ENC, 06-14-2012 18:13:08
Tom........you ask........"what is a "idiot lamp".......what do you think an idiot lite is??? Ittz fer DPO (idiots) that can't read the amp gauge. It is also cheaper so Detroit likes to use idiot lights 'stedda' expensive gauges. Simple, eh?
The idiot lite is used in the switched "excite" line from the simple 2-terminal ignition switch. Without the idiot lite, you can NOT turn yer engine OFF (as you found out) as it sneaks volts back to the ignition coil.
The bottom middle post of the original 3-terminal "infamous ballast resistor" is always HOT, so I'm not certain why you claim you could turn yer engine OFF???
You can buy "idiot-lites" at yer local autoparts store. Except they call'um trailer clearance lites. Just install between ignition switch ON terminal and alternator EXCITE terminal. And yer Delco 10-SI alternator will work just like God and General Motors (Delco) intended. Simple, eh? .........Dell, a 12V advocate for the right reasons; who knows 8-ways to convert to 12V and they all work right the first time
[Reply]  [No Email]
Ken(Ark)
06-14-2012 21:01:57
173.185.124.147
 Re: 46 2N 12V conversion problem in reply to John,PA, 06-14-2012 18:13:08
You will not need a diode if you use a light , which you probably have something you can rig up to test it out . Save your light contraption as they are handy testing coil and starter switch problems .
[Reply]  [No Email]
Tom Beddard ENC
06-14-2012 19:33:38
173.219.96.189
Thanks Ken- I ll get a diode & a light.tomorrow. I understand now that the diode will allow me to shut it off with it wired properly. It was a cheap conversion, friend gave me the alt, found a ballast resistor in the shop & made the brackets. So I guess few bucks for a diode ain t bad. Thanks for your help .
[Reply]  [No Email]
Ken(Ark)
06-14-2012 19:07:30
173.185.124.147
The idiot light is supplied with voltage from your ignition switch (+) .
When the alternator is not turning the alternator terminal voltage is zero or ground (-) and the light come on .
When the alternator kicks in the terminal becomes energized (+) at about the same voltage as the battery (+) so there is no current flowing , thus no light .
If your battery is extremely low (-) and the voltage is less than the alternator output (+) the light may glow very dim .
A diode will only let current flow in one direction , if installed correctly , to the alternator terminal . Once the key switch is turned off the diode will keep from back feeding the coil .
I prefer the idiot light and no amp gauge . I use that hole for a temp gauge . About any small 12v automotive bulb will work . I picked up a small 12v lamp and red holder assembly that fits in a 1/2" hole at radio shack for a few bucks .
If I leave the ignition switch on the red light reminds me to turn off the ignition before it melts something .
This post was edited by Ken(Ark) at 19:11:35 06/14/12.
[Reply]  [No Email]
Ultradog MN
06-15-2012 06:56:35
70.56.167.176
 Re: 46 2N 12V conversion problem in reply to Ken(Ark), 06-14-2012 19:07:30
"I prefer the idiot light and no amp gauge "
Gotta say I agree. On the later tractors they only have idiot lights for oil pressure and charging. A big red light on the dash is more apt to get my attention than a gauge.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
