Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: OT: Air Compressor Update
[Return to Forum]
Hec In Omaha
06-05-2012 06:23:24
72.214.239.173
Howdy all,
Last night I removed the tube from the compressor head to the tank. I did this after I ran the compressor and let it trip out at the 125 psi set point. I first loosened the connection at the head and did not hear hissing. So the check valve in the line is holding. Then I removed the check valve to inspect it and it looked good. There were was no gunk inside. I reassembled the compressor and tried to bypass the pressure switch. I basically connected the black wire from the power cord to the black wire to the motor, connected the white wire from the power cord to the white wire to the motor. The green wires were already tied together via a ground bolt on the compressor. When I plugged the plug in it hummed and tried to run but it didn't sound right so I quickly unplugged it before I tripped the breaker. I guess this would rule out the pressure switch? By the way the compressor had 60 psi in the tank when I tried to jump the pressure switch. This is sounding more like the motor or start Capacitor issues? What do you think?
Thanks in advance!
Hec
[Reply]   [No Email]
36 coupe
06-06-2012 03:02:26
69.49.142.24
 Re: OT: Air Compressor Update in reply to Hec In Omaha, 06-05-2012 06:23:24
Its time to buy a new start capacitor.You should have a spare any way.The start cap is the first thing to try.
[Reply]  [No Email]
David Bean
06-05-2012 09:28:03
24.126.223.218
Sorry...I'm running behind with a slow connection.
You heard the unloader...good.
I would agree the start capacitor is next. Would normally suggest putting a meter on the line at the motor to make sure you have proper voltage. Low voltage can act the same way.
You have to get to the capacitor to look at it's uF rating anyway, so check for loose wires on the posts of the capacitor. If you have another motor with a capacitor near the same rating you can temp wire that in to check. Might save you a trip?
[Reply]  [No Email]
David Bean
06-05-2012 09:21:28
24.126.223.218
I'll have to agree. While you might first suspect a start capacitor, the clue is that it runs and builds pressure after you bleed it down. A weak start capacitor will SOMETIMES start a motor, but typically won't.
When it pumps up to 125, or while running you turn it off at the pressure regulator using the pressure regulator switch (if it has one), does it give a big HISSSS of air? That is the unloader doing its job. Compressors don't like to start under pressure (very hard to turn). Many of the unloaders are part of the pressure regulator. Sometimes you can trip them manually. Remove the cover of the pressure regulator to get a looksee (power off first). Sometimes dirt daubers like to build in there and foul up the works.
...or remove the belt and see if the motor starts each time you give it power. Then you are diagnosing the motor startup only...
[Reply]  [No Email]
Ron-MO
06-05-2012 08:56:30
63.87.140.3
You did not comment on whether or not you have an unloader valve, or if it is working. I still believe it is the unloader valve (not pressure switch). Usually with a bad start cap the motor will not even start with zero pressure. Sounds like it is attempting to start with full head pressure on your compressor.
[Reply]  [No Email]
Hec In Omaha
06-05-2012 09:07:58
72.214.239.173
 Re: OT: Air Compressor Update in reply to Ron-MO, 06-05-2012 08:56:30
Ron,
It does have an unloader valve. It is electrically actuated. I can hear a PSSSSH after the compressor cut outs out. I am assuming its the unloader valve doing its thing? If it wasn't working, wouldn't I have had pressure in the pipe from the head to the tank?
Hec
[Reply]  [No Email]
Ron-MO
06-05-2012 09:21:38
24.177.135.98
 Re: OT: Air Compressor Update in reply to Hec In Omaha, 06-05-2012 09:07:58
Ok, I reread your message and sounds like unloader is indeed working. My next step would be to try a different start capacitor. You may have two capacitors - a start and a run cap. I know mine does.
[Reply]  [No Email]
asphelt
06-05-2012 06:37:49
99.191.115.233
Sounds to me like the start capacitor.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
