| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8n head
[Return to Forum]
| Author |
[Modern View]
| BrucePa
05-31-2012 12:56:15
206.251.20.173
Started my dear 8n the other day white smoke poured out the exhaust hm! Looked in the radiator and found some oil in the water. Took the head off and found no obvious blowouts in the head gasket. Took the head to a machine shop where the man said the head was warped. Is it possible that the gasket was bad and I could not see it and can a warped head bleed water into a cylinder? Also how much can you shave off the head before the pistons hit the head? Thanks for any advice. |
[Reply] [No Email] | |
| soundguy
05-31-2012 15:02:17
107.41.93.107
Re: 8n head in reply to BrucePa, 05-31-2012 12:56:15
| | if you do have it shaved.. lay it on the deck sans gasket and plugs.. use a couple studs / bolts as alignment dowels.. roll engine over to see if the head moves. if no.. it's good. if it does rock a lil.. relieve the places with a die grinder that touch... |
| NOXJohn
05-31-2012 14:00:42
184.6.199.240
| Look at the spark plugs you removed. A head gasket leaking into a cylinder will normally be indicated by the plug in the leaking cylinder being steam cleaned. That plug will look a lot cleaner then the others. You can shave only several thousands off a head before the piston will hit the head. The other problem is there is no way to see if the head has been shaved before. That is not as big a deal as it sounds. After the head is shaved set it on the block with no head gasket. Rotate the crank and see if any pistons hit. Grease on top a piston is a good way to determine if it hits. If so you will need to grind out the combustion chamber on the head to get the clearance. PITA but not difficult to do. |
| Elvin Frank
05-31-2012 13:25:36
98.67.200.76
| very little, was there water in the oil |
| William Fissell
05-31-2012 13:07:54
76.190.179.70
| dunno, but i have a spare head if you need it. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
