LarryD(VA)
New User
I was having trouble lifting my disc and tried to diagnose the problem using advice here. Took off the right side hydraulic cover and did not see a large leak or fluid flow from the top cover. When I pushed the control rod forward, the lift arms raised an additional several inches. I ordered Zane's adjustment jig, new lift cylinder and NAA piston and pressure relief valve as I figure if I was going to go to the trouble of tearing this down, I'd be prepared to replace what was needed. Today I pulled the top cover and found the lift cylinder to be in excellent shape...almost new looking. The cam pin is worn nearly in half and needs replacing. I noticed the existing cylinder does not have the clearance shoulder ground in it (like the new one I got from GVT) and am wondering if that is limiting lift travel? Anyone have experience with this?
