(quoted from post at 12:07:50 02/29/12) As a card-carrying EE, I am a little startled that themionic emission would be enough of an effect to drive a decision positive vs negative. Are you suggesting that since the mobile charge carriers are negative (electrons) having the spark plug 'hot' be negative and the 'ground' be positive gave a hotter or better spark?
I had wondered whether in part the decision was based on cathodic protection - which would not favor a positive ground system.
http://en.wikipedia.org/wiki/Corrosion#Cathodic_protection
interestign discussion
ot likely much here that you don't already know, Bill.
There is a reason spark coils are wound the way they are. Positive and negative ground coils are wound in different directions in relationship to each other. Spark coils are wound in such a manner that the high tension connection on the coil goes negative when the distributor points open. This means that the rising potential at the spark plug is negative. Why would one want an operating condition where the rising pulse from the spark coil is negative?
The center electrode in a spark plug runs hotter than its grounded electrode. Since electrons can be striped off of a hot electrode more readily than off of a cold electrode, the center electrode is made the negative electrode. The result of this choice is that the arc across the spark plug electrodes can be initiated at a slightly lower potential when the center electrode is the negative electrode. In this manner, thermionic emission aids in the establishment of the initial discharge. A vehicle will run with either a negative output or a positive output from the coil. Millions have operated with the “incorrect” high tension polarity from the spark coil for many years. So it requires a slightly higher potential to strike the arc when engine is up to temperature- big deal. This polarity reversal occurs when converting to negative ground. After the arc (plasma) has been initiated, the circuitry oscillates and the thermionic emission consideration becomes meaningless for that portion of spark duration.
Conclusion -- The coil will work and your tractor will run no matter what you do. If you want to be sure that you have the slightly more desirable initial negative output then pay close attention to the polarity of the primary connection. The primary terminal marked (-) must connect to the (-) terminal on the battery.
Also, Think about a vacuum tube. The purpose of the heater filament is to heat the cathode (negative source point for the electrons) to increase electron thermal energy/mobility so that they will more easily depart as they are attracted to the Positive plate of the tube. It is physics. A very good analogy is the heating of water such that molecules can leave the liquid body, evaporation.
The next point of confusion: The high voltage provided by the secondary circuit of the coil has absolutely nothing to do with whether the battery is POS or NEG ground. That is determined by the direction of current thru the primary of the coil and by the direction of the physical windings of the wire on the coil's core and the way the primary and secondary wires are connected. We can't change the last two items inside the sealed coil, but the manufacturer can. We can change the current direction by connecting BAT+ to coil + and BAT - to coil -, or BAT+ to coil - and BAT- to coil +, thus causing the High Voltage out to be either NEG or POS as we choose. EXCEPT, EXCEPT in the case of the front mount distributor Ns, where due to the lack of easy access to the coil's points side connection (springy thing), you really do not have this choice. Somebody will say I'm wrong & that you can reverse these connections...yes where there is a will there is a way, but do you want to butcher your tractor? The difference is too minor to loose sleep over. Contrary to the popularly stated "you will lose 20 to 30% (or any number someone pulls out....seems that it increased with each repeating of the story) of the coil's spark energy", you will not lose spark energy. It is ever so slightly easier to initiate the arc when HV is negative, but once arc is initiated, the full energy is still transferred from coil to arc whether positive or negative. Further more, when starting, remember, the plug electrode isn't hot yet and this is exactly when you need the best spark possible (cold start). So, not to worry, it will run just fine either way as millions have for years.
More:
explanation to this question comes from a 1978 Rolls-Royce Enthusiasts' Club service manual.
"...it has been found that cars wired positive earth [ground] tend to suffer from chassis and body corrosion more readily than those wired negative earth. The reason is perfectly simple, since metallic corrosion is an electrolytic process where the anode or positive electrode corrodes sacrificially to the cathode. The phenomenon is made use of in the "Cathodic Protection" of steel-hulled ships and underground pipelines where a less 'noble' or more electro-negative metal such as magnesium or aluminum is allowed to corrode sacrificially to the steel thus inhibiting its corrosion."...
For more information on cathodic protection, please read Roger Alexander's article, An idiots guide to cathodic protection or Chris Gibson's article What is Galvanic Erosion, is it serious and can it be prevented? for metal boat hulls. By 1956, all the North American manufactured cars and trucks, except the Metropolitan, were using negative earth [grounding].
Also:
"In most modern automobiles, the grounding is provided by connecting the body of the car to the negative electrode of the battery, a system called 'negative ground'. In the past some cars had 'positive ground'. Such vehicles were found to suffer worse body corrosion and, sometimes, blocked radiators due to deposition of metal sludge."
>>>>>>>>another of many tales:
1923 Model T was built as 6 volts, negative ground. Still is. Somewhere about the time Ford switched to the Model A (1928) the thinking of engineers was that Negative meant charged with electricity, and if the body of the car was charged, leakage to the earth could occur in rain or snow, or if you parked touching a bush, etc. They also worried about wire wheels, which replaced the old wood spokes, and tire rubber with a high carbon black content, making for more leakage. They used this theory to explain frequent dead batteries, which we now know was mostly due to poor construction of battery cells. So, they switched to positive ground.
the bottom line here is electricity could care less - as long as it has a path to follow it'll be as happy as a tornado in a trailer park.
