8N fuel pump
OK8N
This is the first time I've heard about a bad fuel pump on an 8N.
<A HREF="http://www.ebay.com/itm/ford-8n-tractor-running-fuel-pump-went-bad-has-been-parked-since-/220889968271?pt=LH_DefaultDomain_0&hash=item336e116e8f">On eBay:</A>
ford 8n tractor was running when fuel pump went bad,has been parked since.
Either gravity doesn't work in Arkansas or it has an industrial engine transplant with a fuel pump! Most likely a clogged fuel line - plus other problems.
I think the seller made a misprint on the number of years the "so-called" fuel pump went out. Just add a 4 in front of the 2, making is 42 years. Look closely and you might see a tree stump that was once a twenty foot tree had grown up under the tractor.
(quoted from post at 19:38:15 11/08/11) This is the first time I've heard about a bad fuel pump on an 8N.
&lt;A HREF="http://www.ebay.com/itm/ford-8n-tractor-running-fuel-pump-went-bad-has-been-parked-since-/220889968271?pt=LH_DefaultDomain_0&amp;hash=item336e116e8f"&gt;On eBay:&lt;/A&gt;
a ha ha ! He will never see that kind of money!
(quoted from post at 21:02:20 11/08/11) My read . Probly a Jeep (WW2) engine.
ot very likely as the jeeps with the N engine were essentially prototypes &amp; small in number (4,456 out of the 650,000 WWII total) &amp; once production ramped up with the 'chosen' Willys engine, most of those with Ford N engined jeeps were shipped to allies so that we didn't have to provide logistics for the 'orphans', &amp; with no parts available they soon disappeared. Note: Ford actually was a manufacturer, among others, of the Willys designed engine.
I came across one of those Ford GPs a couple of years ago. Elderly father of a guy I sold a tractor owned it and let me have a gander at it.
It was in a dark shed so the pics could be brighter but...
Ford GP
