A couple weeks ago I replaced my alternator with a 3 wire Delco 10-SI on my 2N front mount distributer. I soldered radio shack diode 276-1661 on the 18 gauge wire before the alternator as shown in the photo. The white band is on the alternator side as shown but the diode was allowing battery voltage back through the alternator. Today I replaced the diode which I checked was working properly before I hooked up the battery. After the battery was connected I measured 12V again at the alternator. I then checked the diode and found it to be leaking voltage again. What could be the problem?
Thank you,
TB in MN
Thank you,
TB in MN
