Next week I am going to start fabricating my idea for live PTO for the four speed and the 9n/2N tractors.
I have the idea to use the same principle as the tractor jack for the three point hitch. This will be especially good when pulling a PTO hay bailer etc.
I plan on fabricating a heavy axle with two wheels. One on each end and have it so the wheels are up when the lift is down and when the lift is raised the wheels will make contact with the ground and lift the tractor drive wheels off the ground allowing the PTO to continue to turn the baler etc. When the baler cathces up the lift can be lowered to allow the tractor wheels to come back in contact with the ground and away you'll go again.
May have to put springs to raise the two small wheels back up????
I'll post pictures if and when I get it done.
Zane
Zane
