Ford 8n loader
Carl Koeppel
New User
I have a 1952 ford 8n tractor. I want to put a front
end loader on it. Where could I go to get a NEW
loader on my 8n? Not an old loader with all of the
cylindrical tubing, but a new light weight loader
that doesn't have to lift very much. I live in
Wisconsin.
Thanks, Carl
Though not certain, I would be surprised to find anyone making new FELS for N series tractors.
That said, there ar e plenty of used loaders for N series tractors that are not made of "tubing."
Dean
I'm not aware of any "new" loader available as a bolt-on for an N. But, there are a lot of things in life I'm not aware of, so maybe there is one out there.
That being said, I'd buy another N to put a loader on. I've got 3 8N's; one trailer queen & 2 workers. One of the workers is a 1951 w/ a Freeman loader. If I could only own one N, it would not have a loader on it. The N doesn't have PS, so a loader makes it very difficult to steer. (my wife can't drive it) Stopping it on a down slope w/ a full bucket is a real joy as well. Maneuvering around trees, etc, w/ that bucket out there isn't fun either. Some require you to chain the lift arms down to operate the loader. And, try a simple 5 minute repair job (points replacement) w/ some loaders attached & you will not be happy. Worst of all, the N wasn't designed to carry the weight of the loader & the load, so be prepared for split radius rods & worn out front end parts.
As an alternative, a rear scoop bucket on an N works very well.
As to ease of detachment like the new loaders feature.....it's not going to happen. The old loaders weren't meant to come off & on in 5 minutes like the new ones.
I built a frame to hold the lift cylinders, arms & bucket for my loader. I drive in & 20 - 30 minutes later & a lot of lost fluid, it's off.
There were at least 5 (& probably more) loaders built for N's; Wagner, Freeman, Dearborn, Davis & Sauder come to mind. Each has certain advantages over the other, (e.g., the Sauder does detach quicker) but all share the common disadvantages I mentioned above.
50 Tips
This is the Davis loader that I have on my 8N. The picture is not the exact one that I have on my tractor but it shows the whole loader without the tractor. I've had it on my 8N for 8 or 9 years with no problems and it gets plenty or use. But as was said, be prepared for a slow lumbering beast when you put a loader on your 8N.
It is powered by a front mount pump that works off the crankshaft.
Paulson is a good name in the Upper Midwest and they have made loaders for many makes and models of tractors. I considered putting one on my 8N, but a new one will set you back as much as the tractor itself. They also have a drawback of running off the N"s internal hydraulics, which are very slow at 3gpm.
Colin, MN
Paulson Loaders
(quoted from post at 20:08:53 08/21/11) I have a Davis FEL on one of my tractors- works well but as you say it is a bear to steer.
Do you have 6.50 X 16" truck tires on the front as I do?
(quoted from post at 14:22:59 08/21/11) I have a 1952 ford 8n tractor. I want to put a front
Wisconsin.
Thanks, Carl
Paulson makes a lightweight loader for the N series. Their standard offering is power up gravity down with a trip bucket and is powered off the internal hydraulics requiring you to lock down the lift arms - e.g. no 3pt with the loader. They can add a hydraulic bucket, down pressure, and/or a front mounted pump for additional $$$$. Cost for the basic unit is considerably more than the price of a good 8N and the options run it even higher. Quite frankly the most cost effective solution is to replace the 8N with a more modern tractor/loader combo.
TOH
(quoted from post at 22:51:16 09/13/11) yes, what is this TLB you speak of?
TLB = Tractor Loader Backhoe - a "tractor" specifically designed for use as a backhoe - something along the lines of this Ford 555 TLB.
They are available in many different makes and sizes - a bit more $$$ baut a lot more digging machine than a 3pt hoe. If you only need it for an occasional job you can rent a big late model TLB for about $100/day. The second picture is the Case 580M I rented for a week ($550) when digging the foundation for my shop - electronic F/R shift 4WD with enclosed cab - Schweet! I've had it here several different times - well worth the $$$$.
TOH
(quoted from post at 13:54:11 09/14/11)
TOH
nice, thanks
