Tractor will not start. Fresh gas and flowing, float in carb fine, cleaned entire carb 2 times. Little dripping out of drain plug when cranking, but not a lot. 90+ compression. Plugs dry. New rotor, condensor, distrib. cap, points, gqpped right. Great wires, nice spark, new coil. All I can figure at this point is timing. I tried to use the t-square method, and it seemes timed right, but I have to say that the cam tangs are not totally square...so it's not all that easy to check using that method.
Tractor ran last sat, after looooong cranking.
