Charlie1243
New User
I have a front mounted distributor on an 8N,serial #8N-79164. I installed the Pertronix in the existing distributor and found an appropriate place for the new coil.The instructions indicate to run the ignition black wire directly to the ignition switch wire.My ignition switch has two wires, black and yellow, which I believe both presently goes to the resistor assembly. So where do I connect that black wire from the Petronix? And then what do I do with the existing coil power wire that is in the wiring harness and was connected to the original coil terminal?
As always, thanks for your help,
CM
