Charles Krammin
While plowing and discing on a 90 degree day this week, with the Ford 600, I experienced "Vapor lock". Openned gas cap (vented and no noticable presure) and could visualised bubbles coming out of tube for sediment bowl, in bottom af tank. Also could get off tractor and walk around it (either direction (Ha-Ha) and vapor lock would subside.
Do the Marvel-Schebler carburetor, have a outside vent, above the float that could be plugged ? Is the vent by the butterfly in the air tube and be wired out without dismantling carb body?
Michigan subsidize "Ethanol" Does this type gas vaporise at a lower tempature?
12 volt electrical system has 12 volt coil and ballast resistor and new distributor and coil and points and good advance, so have ruled this out as a problem.
Motor recently completely rebuilt.
Charles Krammin, OT, SW MI
