[b:0a32043b2e][i:0a32043b2e]I should know better!!! BUT.....Dan in CO., said I pay attention to detail, inside and out!!! Well, I must be looseing my details, cause Dan's carb., did not even start to pass testing!!!????
Carb. idled OK, but when it came to throttle up, and back down to idle, it was spittin' and sputterin', all over the throttle quadrant. OK, so I blew that, and had to take it off Hermie.
Tore it down again, and started checking the passages!!!! Second passage I checked......guess what...???.....carb was NOT as clean as I thought!!!!! Econo jet, can't do it's job, if it has a small piece of blasting media stuck in it!!!!!!!!!!!!!!!!!!!!! :shock: AND, I KNOW I checked that before putting it back together.!!!!! Yahootie, must have put that junk down there, after I checked it.!!!!!!!!!!! :twisted:
All you guys that, state "yer carb is clean??????" TAKE HEED!!!! :lol:
Dan in CO's carb:
Clean as a whistle, on the outside:
Piece of crud, on the inside!!!! Won't run very good!!!!!!
RE-TEST's.....@ about 11:00 AM today!!!!
Gary :x [/i:0a32043b2e][/b:0a32043b2e]
Dan in CO's carb:
