hen the arrangement is "suck thru the carb, into the blower, then blower into engine, the carb can be made to work, BUT blower pumping into carb, then carb to engine will TOTALLY upset the fuel metering/bowl pressure system. Where this has been done with Paxton blowers, Studebaker, Thunderbird, etc., the procedure is to put the carb inside a box & pressurize the box, thus keeping a balance in the carb throat/nozzle & bowl pressures.(quoted from post at 12:18:37 02/15/11) Bringing this back from the dead. Do you have to add a electric fuel pump rather than the gravity fead tank ?
aybe it will work out for him. I do see your point.(quoted from post at 21:37:06 02/15/11) Respectfully, I"m not so sure about that JMOR. The M-S carb is a pressure balanced design. That means that the carb inlet is connected to the fuel bowl via some large vents. This was done to make the carb metering insensitive to air cleaner restriction. The carb meters on delta p not the abolute level of pressure. The absolute pressure has some other effects (Reynolds Number effects)however.
You would, however, need to rejet the carb becaused of the increased airflow with a blower no matter where you put it relative to the carb. Rejetting will be the tricky part of this type of modification. I think the where you put the blower relative to the carb will be determined by the ability to keep it sealed if you place it behind the blower. It"s really not mechanically designed to be pressurized.
Then you have to deal with some cooling concerns also because the peak as tempertures are going to be a bit higher depending on how much boost you apply. Then there are the increased loads on the mechanical components......
Anyway, it"s an interesting problem.
(quoted from post at 13:36:21 02/15/11) Duggan........yep, I would. ........Dell who advocates using the smog-pump from a 454 Chevy-V8 as a belt driven supercharger using a carb from the NAA so the mouth faces the pump
(quoted from post at 11:37:25 02/16/11) Put a small pulley on it and speed it up.
aybe it could function as a belt driven choke?!(quoted from post at 09:15:20 02/16/11) have you ever ran the numbers as to the CFM requirements of a N series engine and compaired that to the CFM of air supplied by a smog pump?
The smog pump comes up very short of providing enough air to raise intake manifold PSI.
You claim to be a engineer so I would have expected better from you.
is article is all talk & no meat. For me..............I'll rely on the numbers. Have totally disassembled a Ford 302 smog pump & know what is in there,,,,,,,,leaves me a skeptic for now.(quoted from post at 15:17:39 02/16/11) indyguy.......don't haffta look up no numbers. You doubt? Look-up "dirt cheap suppercharger" by Steven Richman. Google is yer friend. I can't be engineer fer everybody. .......respectfully, Dell
(quoted from post at 12:38:27 02/16/11)is article is all talk & no meat. For me..............I'll rely on the numbers. Have totally disassembled a Ford 302 smog pump & know what is in there,,,,,,,,leaves me a skeptic for now.(quoted from post at 15:17:39 02/16/11) indyguy.......don't haffta look up no numbers. You doubt? Look-up "dirt cheap suppercharger" by Steven Richman. Google is yer friend. I can't be engineer fer everybody. .......respectfully, Dell
(quoted from post at 20:38:27 02/16/11)is article is all talk & no meat. For me..............I'll rely on the numbers. Have totally disassembled a Ford 302 smog pump & know what is in there,,,,,,,,leaves me a skeptic for now.(quoted from post at 15:17:39 02/16/11) indyguy.......don't haffta look up no numbers. You doubt? Look-up "dirt cheap suppercharger" by Steven Richman. Google is yer friend. I can't be engineer fer everybody. .......respectfully, Dell
ou are correct & it is trivial to calculate the 'maximum' that the engine needs, BUT no one has verifiable, hard numbers on the smog pump output volume at various RPM & pressures, or volumetric efficiency of the engine, so we are at a point where rumor & speculation rules!(quoted from post at 21:38:52 02/16/11) I love your reference to "Red Green's Possum Lodge" I use to find
their tape and incorporate it in the lesson plan. While the show
didn't provide must for leaning content. But it did in way. But I
would put the in the move to the lesson plan. It would get the
students interest
. Which if you can do that , you got three battle haft won. It was
a Carpentry class of 10th thru 12th grades. With students
coming from up to 5 difference High Schools. Talk about gang
war troubles?
Well, I didn't want to get off on that. Seem the idear could be
tested using an air compressor. Find out what the gan is and
then the the replicate the into the tractor as needed. It reallly
just a matter of have much air needs to be moved and what is
going to move it
