Durkee
New User
Is the Pto shaft on a 2n and 9n smaller than a 8n? The reason I ask is I have a Pto pulley that was suppose to fit on a 8n but the 8n pto shaft is just a little bigger than the female end on the pulley. If not what could this pulley have been on?
You need an adaptor,or overrunning coupler to have a 1-3/8 spline at the pto output.Either one would get the same results,but with an ORC,you get safer operation of bushog,etc.---lha
The posters below are correct, Durkee.
Ns were originallyequipped with the then standard 1 1/8" PTO shaft and many many PTO pulleys for 1 1/8" shafts were made and sold.
Most Ns have subsequently been retrofitted with the now standard 1 3/8" PTO shaft.
By the time that the 1 3/8" shaft became common, few folks were still using belt driven equipment so few PTO pulleys for 1 3/8" PTO shafts were sold. As a result, these PTO pulleys are much less common.
Dean
Like the other fellers mention, Your 8N has the updated 1 3/8" pto shaft... To use the pulley set up, just find one of the old style 1 1/8" pto shafts, complete with the bearing housing. Then, simply park the tractor on a downhill incline, remove the four bolts that hold the bearing housing and swap out shafts..
Thanks for the Info guys! Now here's my next problem. I bought that belt pulley and a 3pt buzz saw,I since have sold my 8n and bought a MF 50 which has the 1 3/8" pto also other wise the pulley would bolt right up to the MF. Are the 1 3/8 belt pulleys hard to find? I sure would like to be able to use this buzz saw! Thanks again!
