1941 9N 6volt front.
Was mowing... stalled out, not sure if it was low fuel, or junk in the fuel that caused it. Tried to start again, and the bendix broke off the starter. Replaced that still would not start. Turns over but will not "catch." Pulled carb, cleaned it blew out all the holes. New plugs, cond, points. Sprayed starter fluid in the carb and in each plug hole with no luck. When I pulled the plugs they were still clean and dry. Carb will flood with excessive cranking and spills out the bottom. Turned on the gas with the carb bolt pulled and watched the gas flow out of it.
Any help is greatly appreciated. THANKS.
