Hello all.
I was a heli mechanic in the navy so I have a 'decent' understanding of tools and mechanical repairs.
BUT.. I have came into the ownership of a 9N.. probably 1950+.
I was told by the P/O that this one had a 12 volt conversion but it started dieing after about 45 minutes. I did some research on the web and found that it might be the coil.
I went and got a 12V generic coil and installed it.
I have been very careful not to leave the ignition on at all when it is not running and it has started doing the die-after-it-is-warm thing again.
I read the article here about 12V conversions (ty for that). However, the article mentions using/retaining a 6 Volt coil.
I presumed mine was a 12v (when I did the replacement last fall) so that is what I purchased and installed... I also I noticed no ballast resistor on the wire to the ignition as I replaced the coil. This and a lot of ignorance about the 9N lead me to think I was doing fine installing a 12 volt coil.
I guess my questions are:
A) Did I do the right thing installing a 12Volt coil?
B) Does a 12 volt setup with a 12 volt coil need a ballast resistor, if so which one or which value/rating do I use?
C) Is the point gap also .15 for the 9N?
Thank you in advance for this free forum to ask for help and your time.
AF
AF
