I've read a lot in this Forum and another about problems with the hydraulic lift and it's causes. People seem to center on replacing the ram cylinder piston with one that takes an o-ring gasket, replacing the pressure (or safety) relief valve, and replacing the illusive "cam follower pin". I have looked every place I can think of and can find no direct reference to the exact location of this pin in the FO-4 Shop Manual or the Master Parts Catalog. My lift arms will not lift a 6 1/2 foot disc up enough not to drag it on the ground and I need to fix it. I'm very, very new to the world of 8N tractors and to farming. I've just moved to 6 acres and want to grow a few things and this is my first tractor. I've got no family left to help so I thought I'd turn to you folks for some advise on this issue. Thanks in advance for your time, Gene
