I have an 8n with just 1 set of seals-Redid everything last fall and its back to being wet with fluid.
Right side is dry as bone.
So, back at it again-In summary, there's this cork seal that you push down the axle spline, and there's the outer metal seal, that's it, right? The book shows a bunch of other stuff.
Anyway, I did do one thing that I wasnt sure of and that was to take the wide cork seal and slice it in half so it wasn't so big when you shove the hub on. I should have kept it its normal width. Is that the problem? Since obviously fluid sloshes around in the trumpets when you go on unlevel ground...
I did the Dell bottom bolt removal method...and do park on pretty level ground.
