'40 9N Carb
Woodchuck
My 9N has this Zenith carb on it. Idels ok but won't run with throtle open at even a little.
Stumbles and dies. Anyone know what model it is so I can get a rebuild kit?
I picked up the complete re-build kit for the after market Zeinth carb on mine at Tractor Supply cant tell from your picture if they are the same carbs or not the package said 9-2-8 N rebuild kit.
(quoted from post at 07:28:38 06/11/10) My 9N has this Zenith carb on it. Idels ok but won't run with throtle open at even a little.
This YT site under TRACTOR PARTS.
Carburetor Kit, Basic - For Zenith 13876 carburetor on 2N, 9N, 8N. (Part No: BK44V)
P.S. Plane Bart's picture looks like a M/S type, not a Zenith.
[b:7ccd0ecbc6][i:7ccd0ecbc6]
The Zenith carbs were "after market, but work very well on the "N" series Ford tractors.
Here is a list of all the OEM Marvel/Schebler TSX carbs, that were used on
"N" series tractors....OEM:
The best carb out of this bunch is the TSX241B, but all TSX carbs were/are used!!!
Gary :) [/i:7ccd0ecbc6][/b:7ccd0ecbc6]
Woody......the Zenith was after market and NOT original carb. I HATE Zenith carbs 'cuz theys summbutches to adjust. ......Dell
Before you rebuild the carb, are you sure that the carb is your problem?
Check the spark first. If that"s good (FAT, BLUISH-WHITE, the color of lightning)and the timing is correct, then check the fuel delivery to the carb to make sure that it is good.
Make sure the carb adjustments are correct and check for air leaks around the fuel metering part of the carb(throttle shaft, intake manifold to carb conection, cracks or rust spots in the intake manifold, intake manifold to block gasket, etc). If these are good, then consider rebuilding the carb.
It"s best to do some analysis and find the root cause of your problem rather than to jump to a onclusion and start throwing parts at the problem.
I have a buddy that runs one of those on a TO 35. He got tired of dinking with the MS that was on it and hes pretty mechanical. It may just need the main jet opened up or a general clean up. I see no reason for pulling it if on a worker. They aren't cast iron and has much less potential for rust problems.
Pulled the carb and completely dismanteled it. Cleaned everything with carb cleaner. Blew everything out. Reassembled and put it on the 2N. It runs better than ever. Put the MS on the 9N and it's better but I think it still has spark issues.
