8N still running rough so let me go through what I've done. just bought New to me 1949 8N Tractor was running a 5' brush hog fine then one day the JB weld that was on the exhaust manifold gives out and with it went all the umphf other than to limp it back to barn. I replaced Manifold with new replacement that came without a gasket, so I salvaged the original, no breaks but it is tired and probably not sealing enough, but it is quieter new gasket is on order. Checked fuel by removing bolt on bottom of carb, good flow over 1minute. 12 volt converted, replaced spark plugs with new 347's and copper core wires. Compression dry results; #4 105psi (black oily gunk on sparkie)#3 105psi (black but dry sparkie) #2 110psi (black but dry sparkie)#1 120 psi (black but dry sparkie). I changed oil and filter for good measure to find that the previous owner had the wrong filter in the can with no seal so he used silicone goop. Changed Ignition switch and had no better results. front mount distributor cap had #2 tower cracked so I replaced that, there was NO gasket on the cap so I cut one out. I inspected the rotor and cleaned off mild residue, pulled the distributor to look at points and saw the fixed point had been bent out towards housing so only the bottom of point made contact with moving point. I saw that when I rotated the shaft and saw that the arm that was riding over the lobes wasn't really separating the points so I tried to widen the gap and realised I couldn't anymore. Thats probably why the fixed point was bent back. I set the points back to what I thought was previous but Now she wont start. Thats right I killed her. I need help, I need that tractor to work, I've got weeds overgrowing my land, steers and donkeys are getting lost.
