Cam Follower Pin
Anonymous-0
I called my local Ford dealer and asked for a Cam Follower Pin used in the 8N hydraulic system. The dealer parts man tells me there isn't anything in his parts book called a Cam Follower Pin. Is there a different name for this pin. I also have the Ford catalog and I can not find this pin. Does anyone have the part number and/or the name Ford uses for this pin? Thanks in advance.
374072-S, 5/16 x 7/8 dowel pin. You can use a more readily available 5/16 x 1 if you like.
Dean
on the counter mans parts list it should be part 32a, wich is a sub part of 32, the 8n680 arm assy.
dean gave you the number for the pin itself.
soundguy
Buy the 372074-S pin from New Holland. It is .309" diameter. A standard hardware store 5/16" dowel pin is .3125" and is too big to press in the .309" hole in your linkage unless you ream it oversize first.
