I see what folks meant by the instructions being crappy. The "kit" I got included the stuff to completely remove the square can coil and replace it with a cover-plate with a spark plug like terminal sticking out of it.
What I didn't like was that it comes with a new distributor cap the terminal screws in to. That would mean the one you can find at any TSC won't work - I assume the screw-in terminal capable cap would be harder to find.
So - I only used the new igniter plate that goes in the distributor and replaces the plate the points mount to. I kept my gutted square can and the standard crab-cap. The instructions would lead you to believe that there is no need to set the timing. Just said to center the new stud/nut in the adjustment range(even had a pic).
The two wires just connect to both terminals on the coil, red to the positive/key side, black to the other...thats it. My system has an inline resistor on the key side.
It sure starts and runs better and has 'hotter' spark JUST KIDDING!
I am happy with it right now.
I did think of one question: I already lost the instructions but I think they said something about at 3 ohm coil needed. If I get the NAPA coil that doesn't need a resistor - do I need to be concerned about "injuring" the EI?
This coil is obviously VERY old, I'd like to replace it. My OHM meter showed as low as 2.x ohms while I was checking across the coil terminals. Dunno if that tells anything usefull
