(quoted from post at 02:48:39 12/28/09) Innocently enough, I was removing the trumpet to replace the lower lift pivot bolts and this is what I found.
I have seen quite a few like that on tractors I have parted out (they ran they did not fall out of the sky),,,, If it were My own personal tractor it would get replaced...
Its now just a matter of moving the rear case back to get at the pinion,,, you will need a slide hammer to get the pinion out,,, it has a threaded hole in the end just for that....
Plenty of cheap pinion/differential sets on ebay....
WARNING :shock: all I know I read on the Internet,,, do it enuff and you can become a guru also,,, not responsible for damages,,, I read it and just pass it along,,, proceed with caution
