Redid the seals on the Ford. Before I took it apart, did a check and when I rotate one wheel, the other rotates opposite. When taken apart, no wear shows on the inner axle butt end.
Do I need to reshim this so that, as the FO4 Manual says, they turn th same direction?
And, I hate to say it but do the shims go on right after you put on the backing plate, or on the trumpet end before you put on the bp?
