Some of the members here might know of such item that is bolted under the rear of the tractor. This is my Drawbar Support assembly that the 3-1/2" wide bar attached to this bracket and the 3 point hitch.
The 3-1/2" x 1-1/8" pin/ bolt inserts into the bracket with the spring to keep the tension and in turns lock it in place. There are two separate areas for this pin to lock in. This pin has two "prongs" that extend (as per photo) allowing it to lock in place.
Does anyone here know if these "little prongs" can be removed? It is pressed in or welded? These prongs still are good, but they are worn some, as it may be best to replace them now while I have the unit down.
