I first composed this in response to Bruce's post:
http://ytforums.ytmag.com/viewtopic.php?t=520622
But then as I kept expanding, I decided it need it's own stand alone posting with a new Subject line.
I expect that some of the major reasons the round can coils hold up better is that the oil is in intimate contact with the heated wires and conducts to the high-thermal-conductivity metal can, allowing heat to be moved from the wires to the ambient air. Whereas, the old square can units were encased in asphalt/tar/pitch (not the same intimate contact that oil provides) and whatever heat conductivity it had, it has no where to conduct it to other than a very low conductivity plastic case. Thermally conductive epoxy (if the Chinese spend that kind of $ on them today) would help, BUT the thermal path is still blocked more or less by the plastic case.
Take the IC14SB with no resistor and look at it.
14.7v/3.25 ohms=4.5Amps Then running, ~(4.5A X 0.33)=1.5Amps
Pwr steady state=65.8Watts {11.5W}
Pwr running=7.3Watts {1.3W}
Compare to the original FORD sq can numbers in {}
NOW THAT TELLS YOU WHAT THE RESISTOR IS FOR! It keeps the heat out of the coil! (The IC14SB is running at 4.5A & the Ford at 4.8A in these comparisons.)
Since spark energy is proportional to the current squared, there won't be a lot of difference in the two. (Time constrains the inductance).
The RESISTANCE PROVIDES OTHER BENEFITS AS WELL, such as shortening the coil charge up time and stabilizes current over temperature as the coil heats up and its winding resistance increases. Were it not for this stabilizing effect of the external resistor, the coil energy would decrease to 56% of its cold start value, just due to the temperature induced winding resistance increase.
Compare that to the original Ford design with external resistor and you will find the over the same temperature rise from 68F to 200F, it is still producing 90% of its cold start value.
I should name this posting, "BALLAST RESISTOR IS YOU FRIEND", despite all the trouble folks seem to have in using them properly.
So, someone will ask why the IC14SB popularity? Well, I would say ease of use. It is a no-brainer, even if it sacrifices output over temperature and apparently it can handle the additional heat load that it generates. They work & they sell.
Overall, the same heat is there if the battery voltage and coil current is the same........the resistor heat is just transferred from the resistor to inside the coil when no resistor is used & adds to the coils own heat as with the IC14SB.
This same analysis applies when comparing the use of a 6v sq can coil and a so called 12v (2.5 ohm) sq can coil (either one operating on a 12v system).
If properly ballasted, both will provide about the same spark energy (remember, 1/2 x L x I*2) as current can be made equal. But the 6v coil will be running much cooler at ~ 5X lower power (heat) than the so called 12v sq can coil. Compare 11.25Watts vs 56.5Watts in stalled condition and 1.3Watts vs 6.5Watts running.
I do not wonder why folks have so much trouble with the so called 12v (2.5 ohm) sq can coils on 12v systems. It is clear to me, and I hope to others now.
Thank you and good evening,
JMOR
JMOR
